Sony Handycam DCR-HC85 Mini DV Digital Camcorder Logo
Posted on Jun 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony HC85 camcorder. Use as a webcam, need driver
Anonymous
Level 3:
  • Master 448 Answers
  • Posted on Jun 23, 2010
Anonymous
Master
Level 3:
Answers
448
Questions
Helped
145273
Points
1296
It's suggested that you use an AV cable to connect the Camcorder to your Computer to use it as a Webcam. When using an AV cable, it's not required to install any driver.
Transfer issues
You would have to upload the footage onto your pc then onto your sd card.
2answers
Jvc gr-dvl 157 camcorder
wait i will get you the software link
I need a dcr-hc85 driver for windows Vista where can i get it
  • Windows Vista Starter edition is not supported.
  • The USB streaming feature is not supported with 64-bit Windows Vista operating systems.
  • The drivers required to connect most Sony® cameras and camcorders to a computer are already included in the Microsoft Windows Vista operating system.
    Note:
    In some instances, the camera or camcorder may not be recognized by the computer when connected. In this case, check to see if there is an updated driver available for your model.
    If the above link doesn't work, you can check to see if there is an updated driver at this address:
    http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRHC85
    Hope this has helped you.
    www.austintelstarservices.com
    2helpful
    2answers
    Need driver software for Sony GC1 webcam
    your camera has built in sharing software compatable with most services .. you can upgrade that at this site
    http://esupport.sony.com/US/perl/swu-list.pl?mdl=NSCGC1
    2answers
    Need drivers for using sony handicam digital as streaming webcam on windows vista
    If it is Sony DCR-TRV250 camcorder then it can be used with Windows XP through USB Streaming port and no driver update is available so far for Vista. Check further details on Sony Support.
    Thanks.
    8helpful
    Using my camcorder in webcam mode.
    first go to:
    http://esupport.sony.com/US/perl/swu-list.pl?mdl=MHSCM1&SelectOS=30
    -download "Lost the Original Software Installation Disc? Use the Picture Motion Browser Software Download Tool"
    -run "SPUDownloadManagerInst.exe"
    -it'll be extracted to a folder called "SPUDownloadManager"
    -open folder and run "SPUDownloadManagerStarter.exe"
    This tool will download the original Software/Driver which came in the box. Also contain the drivers needed for the WEBCAM to function properly...
    Worked for me. Hope this helps.
    PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30 COMO WEB CAM PARA MI ORDENADOR PORTATIL, ASUS?
    Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
    Primero es para S- Video
    La orta mas pavajo estan directiones para USB Streaming
    How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
    Solution
    sp.gif sp.gif IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
    NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
    1. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
    2. Connect a composite video cable or S-Video cable to the VIDEO or S-VIDEO jack on the camcorder. NOTES:
      • Sony camcorders usually come packaged with composite Audio/Video cables; S-Video cables are sold separately.
      • To purchase either of these cables, check with your local electronics dealer or visit the Sony® Parts and Accessories Sales Web site or by call (800) 488-7669.
    3. Connect the other end of the composite video cable or S-Video cable to the VIDEO IN or S-VIDEO IN jack on the computer.
    4. Turn on the camera by moving the POWER switch to the CAMERA position.
    5. Remove the cassette tape from the camcorder.
    6. Turn on the computer.
    7. Start the webcam application to be used. NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
    [[Direct Accessories and Parts Center, DAPC]] How to use a Sony® camcorder as a webcam using USB Streaming. Solution
    • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
    • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
    • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
    1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
    2. Restart the computer.
    3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
    4. Connect the supplied USB cable to the camcorder and computer.
    5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
    6. In the camcorder menu, set the USB STREAMING option to ON .
    7. On the computer, start the webcam software.
    Hi, I want to record my camcorder footage onto my laptop and edit it using a programme I already have called Easy Media Creator. The problem I have is that my Laptop does not recognise the Camcorder. Do I...
    http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/OTHER-SCANNERS/Sony-DCR-HC19E-TWAIN-Patch.shtml
    Go to this website to download the driver you need. Load it and then reboot computer and it should be able to see it.
    Top Sony Video Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Sony Video Camera Expert? Answer questions, earn points and help others
