Mcdevito75 here, Most Lorus watches use a press fit back cover on their watches, simply us e a knife with a sharp edge between the case and cover and with a slight twisting motion the cover should come off, Also Look for any slots in the cover that match a slot in the case, or a very slight extension or lip on the cover, this is where you"d place the knife and use a slight twisting motion to remove the cover. If there are screws on the back cover you"ll need to remove those screws to get the cover off. Your Local small watch repair shop can help out.
SOURCE: Just to know to open
Watch backs open three ways, the first way is 1) by small screws you will see them and need to remove them carefully as not to strip the screw head, if there are no small screws the watch could have 2) a screw back, it will have indentations evenly spaced all the way around the back, if it is a screw back it has to go to a jeweler or watch repair for removal with a special tool. You must eliminated 1 and 2, then 3) would be a pop off back, you look around the edge of the back for one indentation along the back of the watch, use a pocketknife to gently pop the back loose. I hope this helps! thank you!
SOURCE: i have a lorus mickey
You may need to have a local jeweler who has a watch press to put it back on, If you put to much pressure on the inside of the back, it may be warped. A knowledgeable jeweler should be able to fix that issue also.
Thank you for contacting FixYa..
Jewel
