Question about Watches
Just to know to open up the back of this Lorus watch, to replace the cell ?
Posted by sallygordon4 on
Lisa Christine
    Scholar:
  • 71 Answers
Watch backs open three ways, the first way is 1) by small screws you will see them and need to remove them carefully as not to strip the screw head, if there are no small screws the watch could have 2) a screw back, it will have indentations evenly spaced all the way around the back, if it is a screw back it has to go to a jeweler or watch repair for removal with a special tool. You must eliminated 1 and 2, then 3) would be a pop off back, you look around the edge of the back for one indentation along the back of the watch, use a pocketknife to gently pop the back loose. I hope this helps! thank you!
Posted on Sep 21, 2011
Lisa Rogers
    New Friend:
If we do not have a Jeweler here or a watch repairer. Where can I send the watch too
Posted on Sep 30, 2011
Installed battery in lorus musical watch and nothing.
mcdevito75 here, A quartz mechanism can go bad just like a light bulb, depending on the watches age, wear etc. If your watch was stored for a period of time with a dead battery in it, that dead battery could hve leaked, ruining the mechanism. If your watch worked fine and the battery just went dead, make sure the battery contacts inside the watch are clean, use a Q-tip dipped in Alcohol and gently clean the battery contacts, press the button for the music part of your Lorus and make sure those contacts are clean and are meeting once the button is pressed, this you can see with the back cover off the watch. Makes sure the battery is installed correctly, and that the new battery number is the same as the old battery number. 364 and 371 are popular batteries for Lorus musical watches, even though your new battery is new, it can still be dead, who knows how long it was on the store shelf?? also, double check as some Lorus Musical watches have 2 batteries, 1 battery would be rather large ans sitting just under it"s hold down bracket see, as soon as you remove the back cover, if so, that battery must also be replaced. I have an old Mickey Lorus musical useing a 397 battery just 1 but my Lorus is burnt out. If all this fails, I would look for a small watch repair shop in your area and have them look at the watch for you.
Feb 18, 2011 | Watches
Need to replace battery of lorus mickey mouse pocket watch
Try to find a watch repair shop (sometimes called clock & watch shops). Also, many jewelers replace batteries and do watch repair.
Jan 13, 2011 | Lorus Watches
I just bought an older Lorus Disney Mickey Mouse Musical watch V422-0010 with a box behind this number thia square was around the letters ZO. I cannot get the watch to work. It says, "After installing...
There is no CR920 3 volt battery and especially will not work for any Lorus watch. There is the SR920SW and SR920W series 1.55 volt silver alkaline cell.. 9 mm diameter x 2.0 mm height is an impossible size for this old Lorus watch.
Jan 02, 2011 | Disney Lorus Rare Musical R2306AX Watch
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
Dec 17, 2010 | Disney Lorus Out of Production Collectible...
How to set the alarm on the lorus rf33bx9
If you put "lorus watches" into your search engine you should come up with the Lorus web site.
One of the options given is "instructions", click on this and you will be asked to enter details off the back of your watch.
Feb 11, 2010 | Bulova Watch
I have a Lorus NX11A multifunction watch and have no manual. I have been on the Lorus website but it might as well be written in Japanese
mcdevito75 here, I would imagine this is a Mickey Mouse Lorus watch by the picture supplied. If it Has DAY / DATE function, here"s what to do, --- To set the DAY, pull the stem out to set, keep turning the hads till you rech the day, then push in the stem. To Change the DATE 9 number) slip your fingernail just under the stem and lift it to it"s first position (notch) this should allow you to change the DATE (number) without haveing to turn the hands so many times.
Jun 24, 2009 | Disney Lorus Out of Production Collectible...
Watches Logo
2,686 people viewed this question
Top Watches Experts
Bruce Robin
Lisa Christine
Lisa Christine
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
