Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board. http://electro-medical.blogspot.com/
Due to the nature of the board connections and design; you need to use the exact replacement made for your model. Yamaha made the original and any other clone (if available) may not function properly. You could end up wasting your money. Either get the Yamaha replacement, or look for a used model in eBay or the internet. Other than that, use the $477 as a down payment on a new system.
no and no. the CPU or Processor is not included in a motherboard. if your buying a completely different board from the one you have you may need to expend a few hundred more to buy a new processor to match. also you may have to buy new RAM depending on the new board vs the old board. also you need to match up the PIN number of the board to processor. if its a 966 pin you need a 966 pin processor to match. and RAM DDR1,2,3 to same.
you do not need to buy a new hard drive as long as you dont need a new one. but when you replace a motherboard windows will demand you re enter your activation key before it will open right back up to you. so make sure you have it handy.
U can't buy the T-CON board in any stores in anywhere in the world because this T-CON board it is not buy able it new u only can buy it as a salvage tv PCB board only.This T-CON board u can buy it as refurbish board only.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Try website like Tvrepairworld.com,Ebay.com to buy a refurbish mother board,they might have it.Don't it time to buy and replaced for a LCD tv better tv over all as a tv and for buying for replacement parts later for replacement for tv needed parts later on as LCD tv needed circuit board for parts.
Why do you need to buy a circuit board ? Did you try replacing the Capacitors? replacement circuit boards cost almost the same as the price of new monitor.
