My frigidaire affinity front load washer machine won't go through the spin cycle and leaves water in the bottom of the drum. If i manually select "Spin" it will drain the water but still not spin.
Hey friend, thank you for allowing me to assist you!
It is normal to have water in the tub after your Frigidaire washer has completed the final spin cycle. The water that is in the tub is there to help prime the pump. Hope this information is helpful. -Matt
I see that your Frigidaire Affinity washer, model# ATF7000E, is buzzing and will not cycle. Some possible causes of this could be:
-Your washer is overloaded with clothes. Try taking some clothes out and restarting.
-There could be an article of clothing that might have slipped in between the gasket and the drum that might be stopping the drum from spinning. Check to see if there are any clothes that might be missing and possibly stuck between the drum and gasket.
If you have tried the above solutions and are still having trouble, I suggest giving your washer a hard reset. You will do this by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. After the time has passed, restore power and start a cycle. If your appliance is still buzzing and not spinning, I suggest that you contact your local authorized technician for further assistance. They will be able to diagnose your washer and determine the cause of the buzzing and why it is not spinning. Hope this is helpful.
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
use a shop vac and attach it to the end of the drain hose remove all the water then you need to check the drain pump and see if there is anything blocking the pump.
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
