Averatec 3150H Notebook Logo
Posted on Sep 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laptop will not boot when turned on
Laptop had a virus and it wiped out the programs, took to be repaired and was told I needed to install recovery disk. I installed the recovery disk which can with the laptop but it had a crack in it so I ordered one over the internet. I now insert the disk and it ask's me a question about the output A:\GHOSTERR.TXT. wHEN i CLICK ON YES IT SAYS CANNOT OPEN gHOSTEER.TXT.
richie46
Level 3:
Top Expert:
  • Averatec Master 12,962 Answers
  • Posted on Sep 11, 2017
richie46
Averatec Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2946342
Points
58151
Go into bios and make sure that your cd player is set up as the first boot up device. Then insert the disk, reboot and follow the prompts to install the OS. When thru get the drivers you need and you are good to go!
1 Related Answer
Anonymous
  • 624 Answers
  • Posted on Feb 17, 2007
SOURCE: Continuing formatting trouble
Hi Shawn, It sounds as though your recovery disk has Norton Ghost incorporated into it, thus the call for the Ghosterr.txt file. Most recovery disks are just modified Windows installation CDs and if you boot to them they will immediately go into the Windows recovery which is what Sandrew was trying to walk you thorough. Having said that I?ve found a few other references to this type of issue and has usually been a result of CD read errors. - Try cleaning the recovery disk, if there are severe or numerous on it or if it is dirty that could be your problem. - If that doesn?t do it try cleaning your CD drive with a good commercial cleaner. - If that fails another option is trying a conventional Windows installation CD. Let us know if you have any other questions and please don?t forget to rate this post.
1helpful
My laptop wont boot up
Listen, chances are that your OS is corrupted beyond repair. Suggest that you complete wipe clean the drive , format it to ntfs standard, and then go about with a clean install of windows.
And if your laptop originally came preinstalled with an OS other than win 10, I would suggest that you go with the original OS.. Win 10 will no doubt cause you headaches you do not need or want.
Oh, and before you go any further make sure that there is nada wrong with your hard drive - do diagnostics on it to make sure.
tip
Unable to start Windows
Before we start, always check there are no USB devices/drives attached, or any discs in the cd/dvd drive.
If there are, remove them and try to boot....
Still no windows?......Read on
Depending whether you have a recovery disc, or a full version of windows, you still may be able to repair your installation.
If you have a recovery disc, and you can use it, you will restore your computer to factory fresh state, you will loose all your files/programs. (If you wish to do this you may want to save your files, to do this follow the "LIVE" linux install option (bottom of page)
If you have a windows disc (the same copy as you have installed on your computer), try this....BASED ON WINDOWS XP, JUST GOOGLE WINDOWS REAPAIR INSTALLATION + VISTA OR WINDOWS 7 FOR INSTRUCTIONS ON THOSE OS'S
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup. do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. If repair is available.....
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact
IF the repair option is not available, and you continue to load windows, you will loose everything.
LIVE LINUX INSTALL (google "live linux distro")
IF you want to save files/documents before a recovery or clean windows install, you can download various " LIVE" Linux distrabutions.
You Burn these to a cd as a bootable ISO file ( imgburn is a free burning program that will enable you to make bootable ISO discs).
Some linux distrabutions have built in recovery tools/virus scanners.
Once you have recovered your important files, you can either carry on with the windows recovery, clean install.... OR...you may find that you like LInux, if so you can fully install the linux OS and if its not what you want, Install Windows back in.
After installation dont forget .......
1.Download and install your security programs (Anti-virus/Anti-malware)
2. download drivers from your manufacturers support page
3. turn automatic updates on
NOTE............When you are up and running, and want to transfer any saved files you may have recovered..SCAN THEM with your Anti-virus BEFORE you put them onto your nice clean PC.
All of this information is available freely on the internet, just google your relavent question.
on Jul 18, 2010 • Computers & Internet
Why do videos turn the screen green?
virus is the cause. You are going to have to put in your windows cd and boot from it. Then do a "repair" and hopefully recovery your system if not you are going to have to do a total system wipe.
4helpful
2answers
How do i erase reinstall the computer from the recovery discs?
If you don't have your manual, get it from Acer website. Just run the recovery program and follow the instructions. This is just like formatting, it will overwrite the HDD. For you this should be fine, and even formatting is useless. So Follow the Manual.
I have read problems about erasing, if you don't make a extra partition the recovery system will flag out. Seen the second disk error out and not finish, now you have no laptop.
Read about people who needed a new HDD and put it in and couldn't get the recovery disk's to work.
Like I said, formatting is useless anyway, the only true way to clean a hard drive HDD is to use programs that zero write the drive.
But either way, if you format or erase, you can risk not getting the recovery to work.
If you are worried about malware (virus, trojan) Get Bitdefender or Avira, they have a free virus program. Then if you like it, when you can but it.
These are in the top 5 for today's Anti-Virus. What ever you do don't use AVG.
2helpful
I have a Satellite L305-S5918 laptop computer that when I turn it on ,is saying on a blue screen to insert driver instalation disc . I believe it has a virus,I've got a bart pe cd for that. The person...
Normally computers today have a recovery partition or a recovery disc. you will need one of these to boot the computer up and recover or repair the computer. most of the time its easier to just pull out the hard drive attach it to a working computer carefully copy the files they want or need and make sure to virus scan them and then just do a fresh install of windows on it with a virus protection program as well.
Ntldr missing
NTDLR is the main directory for the OS. This can happen as a result of a virus which in effect wipes windows out. I think that you are looking at a repair of windows using the DVD / CD installation disc.
To do this, insert and boot from the Windows Cd or DVD
Ignore the request to use the repair console
Wait until it finds an existing windows installation (assuming it has not been totally wiped)
Allow it to repair the installation, it should retain all your info but you may need to reinstall service packs etc.
Reboot and see if it works
IF your computer / laptop came with a recovery partition (often pressing F10 on boot) us that instead
My friend has a Dell laptop 1545 that says she has a virus. It will not let her sign on to internet, load a disk or anything? What is the best way to clear this out? I am trying to find a solution online...
If the Sell does not have a virus program installed and she cannot get on to the Internet to use a WEB based virus scanning program, or install a virus program for a CD then the only alternative is to use the Dell Re-installation CD or Recovery CD and wipe/format the hard disk and re-install Windows again..
I have a dell latitude d610 it was virus infected i install the avast anti virus after installation it automatically restarted and its screen become blue no window boot it just show the dell logo and...
It sounds like the virus did something to the boot sector of your hard drive. Once you have been infected with a virus, it's usually too late to install an anti-virus program to clean your computer.
If you have your Windows installation CDs or a recovery disc, you could attach your hard drive as a second drive to a computer that already has a good anti-virus program installed, and wipe the hard drive and reinstall Windows.
2answers
Please re-instate my computer virus protection paid this year,
Hi, click on this website, you can download the "Microsoft Security Essential; I use it, and "recommend it "highly." Rating the solution is appreciated, thanks." http://www.softpedia.com/get/Antivirus/Microsoft-Security-Essentials.shtml
Windows
You may have a boot sector virus. At my bench I would remove your hard drive and install it on one of my towers and run a virus scan on your hard drive. Recovery from a boot sector virus is very difficult using tools found in Hiren's Boot disc, a cdrom that contain various programs to recover a hard drive.
Lastly, you may simply have lost the boot strap loader (even though this doesn't make any sense if you have used your recovery CD and recovery partition with success. If you boot and hear a beep, press F8 repeatedly immediately after the beep and you'll receive the recovery bootup option screen, choose Safe Mode first and see if that works, if not choose last know good configuration and otherwise if offerred choose use System Restore.
If all this fails you as a user you need service from a professional.
Hope this has helped or fixed ya.
Worldvet
Top Averatec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
