20 Most Recent
Acer Aspire 5736z 4460 Laptop Questions & Answers
My Acer laptop will not boot up.
You may have a corrupted video driver due to an update. For some Acers, press and hold F10 when starting the computer. Two beeps will mean that the bios settings have been restored and the machine may boot correctly. If you can enter the BIOS via F2, F1, F10, ESC or DEL, then find the area for display and change it to low resolution then save and restart your computer. Once running, you will need to uninstall the current video driver and have the computer install a new one.
Acer wont connect to internet with either ethernet or wireless.
There is a possibility that there is a fault with the drivers, you may want to contact your local Acer office as the site drivers are not always the correct one, other than being able to look at it personally you may also want to a good local repair/service centre to test the lan and the wifi card, good luck.
Boot mgr is missing what to do?
you can boot off a windows operating disc, either the one that came with the laptop, though most do not come with a disc any more, or find one online.
Why my laptop creat sound when start my pc
What kind of sound is it doing? If it is a scratching noise, then this could indicate a faulty hard drive. I would suggest backing up all your data immediately and get the Hard Drive replaced. If it is doing more than one beep constantly it could be a problem with your RAM or motherboard, if it is doing a windows startup sound, then this is normal, if it is doing one beep before booting into windows, again this is normal.
No bootable device meaning
Either there is a problem with the mainboard connection or the most likely is the HDD is dead and you will need to purchase a new one.
My charger is lose an it sometimes charges an
sounds like a short. could be the charger, but could be the connector on the laptop. does it wiggle at all?if you isolate the cable (don't wiggle the plugged in part) and move it around, can you cause the charging to stop and start by bending your cable? if so, it is definitely a short in your charger and you'd be best off ordering a replacement if you don't want to deal with the hassle.
How do i erase reinstall the computer from the recovery discs?
If you don't have your manual, get it from Acer website. Just run the recovery program and follow the instructions. This is just like formatting, it will overwrite the HDD. For you this should be fine, and even formatting is useless. So Follow the Manual. I have read problems about erasing, if you don't make a extra
partition the recovery system will flag out. Seen the second disk error
out and not finish, now you have no laptop.Read about people who needed a new HDD and put it in and couldn't get the recovery disk's to work.Like I said, formatting is useless anyway, the only true way to clean a hard drive HDD is to use programs that zero write the drive.But either way, if you format or erase, you can risk not getting the recovery to work.If you are worried about malware (virus, trojan) Get Bitdefender or Avira, they have a free virus program. Then if you like it, when you can but it.These are in the top 5 for today's Anti-Virus. What ever you do don't use AVG.
Laptop won't read SD card
have you been tried to use other sd card ? or have you been tried to use other usb slot of the laptop just to know if where the main cause of the problem.
Acer aspire 5736Z wont boot on any recovery options
Try starting up in Safe Mode (Console mode) and type in "SFC /Scannow"Once its done you should be able to do recovery options.If not, boot from the windows 7 recovery/install CD and choose "Repair".Go through the recovery process using the CD and it should all be fine!
