20 Most Recent Averatec 3150H Notebook Questions & Answers
Laptop will not boot when turned on
Go into bios and make sure that your cd player is set up as the first boot up device. Then insert the disk, reboot and follow the prompts to install the OS. When thru get the drivers you need and you are good to go!
9/11/2017 4:57:04 PM • Averatec 3150H... • Answered on Sep 11, 2017
Wireless network ability limited to b
But if your machine's wireless card only supports b - then that's all you will get.
12/27/2014 10:14:08 AM • Averatec 3150H... • Answered on Dec 27, 2014
Where can I buy a hard drive for my Averatec 3150H laptop?
most "mom and pop" computer stores will carry that ide hard drive. Its a 2.5 inch drive
11/2/2013 6:15:25 PM • Averatec 3150H... • Answered on Nov 02, 2013
Audio driver download
7/16/2013 6:47:03 AM • Averatec 3150H... • Answered on Jul 16, 2013
Boot failure
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
9/9/2012 6:28:01 AM • Averatec 3150H... • Answered on Sep 09, 2012
Microsoft has ask me to re-register my xp software?
thats probably that you installed XP with a non valid serial number,try to get a valid onedid you use an original XP cd when you installed your XP?
8/27/2012 7:39:30 AM • Averatec 3150H... • Answered on Aug 27, 2012
Averatec
Try using a Driver Updater www.driver-soft.comCOPY PASTE to your Address Bar
11/24/2011 1:11:34 PM • Averatec 3150H... • Answered on Nov 24, 2011
How do i hook up
If your trying to get on the internet with a wireless connection.and your running WINDOWS.and I am assuming you DO have a wireless router all set up and configured to broadcast the signal (not hidden) ....first we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
try resetting the router (unplug for a few minutes) try --be sure the wifi switch is enabled on the netbook---try---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
this is a link to a troubleshooting flow-chart
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this
12/28/2010 8:02:30 PM • Averatec 3150H... • Answered on Dec 28, 2010
My averatec 3150 runs for a while and just shuts
Feel the bottom of the system- if it is burning hot, you likely have a failing fan/cooling system issue. The symptom you are describing is classic for a system overheating. I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
10/2/2010 8:46:00 PM • Averatec 3150H... • Answered on Oct 02, 2010
Battery Replacement price
Its aprox $150.
9/7/2010 1:36:49 AM • Averatec 3150H... • Answered on Sep 07, 2010
Please provide instructions on how to install
Turn the computer off.
Unplug the AC adapter.
Remove the battery.
Flip the computer upside-down.
Look at the various "bay" covers.
Under one of them will be a slot for RAM.
Take a screwdriver, and remove the cover.
You might either find existing RAM (one stick or two),
or you might find an empty slot.
Now, the difficult part is purchasing RAM that will be compatible with your "antique" (1997) laptop. I highly advise that you take the computer, the battery, and the power-supply to a computer-store, so that they can sell you "compatible" memory -- the "wrong" memory won't fit, or won't work, or will only add 1/4 or 1/2 the amount of RAM present on the stick.
8/25/2010 5:51:21 PM • Averatec 3150H... • Answered on Aug 25, 2010
I WOULD LIKE TO RESTORE MY ALL-IN-ONE TO ITS
if you have CD Recovery with you, just insert the CD restart it, make sure you have set the boot order on cd/dvd drive, and follow the instruction. If you don't have, downloas from this link:
http://www.user-guides.co.uk/cddownload/Averatec/Averatec3150/Averatec-3150-XP-Driver-CD-Recovery-Restore-Disk-116374.html
4/11/2010 7:37:03 AM • Averatec 3150H... • Answered on Apr 11, 2010
2answers
I can't get into my
In many cases you need to contact the manufacture here if its still under warranty. If not you going to need to dig into this laptop and short out the cmos battery to reset the BIOS password.
Now this is easier said then done and I understand that. But what needs to be done is the laptop needs to be opened and you need to reset the bios this is done by taking out or shorting out the cmos battery. If you do not know how to do this you would then need to take it to a tech locally to have it done. They would use something that goes into the usb port that resets the bios $65 bucks.
good luck with this i know its hard work.. please do click the accept button for my efforts. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
3/15/2010 8:26:06 PM • Averatec 3150H... • Answered on Mar 15, 2010
My Averatec 3150 laptop is asking me for my current passwor and I
If you dont remember the password, you will have to download the password recover tool.
The tool can be downloaded by going to the below mentioned link:
http://pcsupport.about.com/od/toolsofthetrade/tp/passrecovery.htm
This link will provide you all the required details.
Let me know if this helps, or if you have any other issue.
3/15/2010 6:59:16 PM • Averatec 3150H... • Answered on Mar 15, 2010
How do i reset bios master password
Locate the battery inside the computer called the CMOS battery. It is round like a watch battery and if removed for about 10 - 15 seconds, it should reset the BIOS to default and also the date/time settings will be incorrect, so be sure to change that as well.
3/14/2010 9:04:07 PM • Averatec 3150H... • Answered on Mar 14, 2010
So today i desided to restore my Averatec 3150H
You can get Bart PE at www.tucows.com online and look it up it will allow you to start-you have no choice. You can start up windows to look at the drive, this is assuming you have Xp or XP professional. It will allow you to reformat the drive, do not format the partition that has the drivers in it unless you have to bart pe also has a disk repair on it to allow you to fix some of the most common problems on windowsxp. If you need averatec's web site for support let me know and I can give you their 800 number so you can call them, there computers are junk I owned one had to replace three mother boards in one year.
11/29/2009 8:18:33 PM • Averatec 3150H... • Answered on Nov 29, 2009
3answers
Averatec 3150hd-01
Yes, you should instead use a windows installation CD or DVD in that case.
8/24/2009 9:00:39 PM • Averatec 3150H... • Answered on Aug 24, 2009
At boot up, my Averatec 3150HS displays the error
Hello there:
boot into bios and look at the advanced section and see if the bridge fan is located there and if it is just enable it than press the f 10 key to save and than reboot the system
8/15/2009 9:46:13 PM • Averatec 3150H... • Answered on Aug 15, 2009
Averatec 3150H Notebook Logo
49 questions posted
Top Averatec Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Averatec Computers & Internet
Most Popular Question
averatec 3150 runs while just shuts
  • Computers & Internet
