Don't know if this will help but our fridge was leaking and then I noticed there was ice at the bottom and it was clogging a drain hole so the water ran out on the floor in front of the fridge. I chipped out the ice, melted the drain hole and slightly raised the fridge temp so the ice would not re-form on the bottom and it worked. - no idea about the fan.
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
How old is the fridge? Mine lieterally caught on fire at the start device last weekend. My fridge was manufactured in July 2001. Be careful, The fridge I have is model# ED5FHGXKQ00. I am currently requesting a recall be made by Whirlpool on this appliance.
Other than that it could just be that the ice maker line has frozen or the "arm" in the ice chest is stuck and can't raise itself to pump water directly into the ice trays. Either way be very careful. I hope this was helpful.
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Assuming the water is on and the ice maker is working, check the ice/water controls, make sure it is not locked. If the water is on, and the controls are not locked your valve is probably defective. It is located in in the back of the machine where the water hooks up.
Your inlet tube that goes to the icemaker may be frozen.To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection.I used a zip tie. If the flexible item won't all the throughto the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connecteverything, you now have ice . . . Solution #2: You may have to replace your "Water InletValve" located at bottom right rear of Fridge.Easy to do, just follow the color codes, be sure and shut off the water.
