Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Leaking and fan stops then starts?
Leaking water and fan stops then starts?
    New Friend:
  • 18 Answers
Don't know if this will help but our fridge was leaking and then I noticed there was ice at the bottom and it was clogging a drain hole so the water ran out on the floor in front of the fridge. I chipped out the ice, melted the drain hole and slightly raised the fridge temp so the ice would not re-form on the bottom and it worked. - no idea about the fan.
Posted on Jun 12, 2014
6ya staff
SOURCE:
Renault Megane Dynamique 1.6 2004 - Heater fan stopped working - wet front footwells
Im almost sure that your problem is a broken or leaking heater core and needs to be replaced cose 1 your coolant level allways will be low due to the leak and 2 it could damage your blower fan motor. if in winter time you need the heat fixit... If not you could cancel the 2 waters hoses going to the heater core. hope this helps.
Jan 28, 2014 | Cars & Trucks
94 plymouth vouyager is starting to over heat when driving for more then 10 mins
This leaking on the passenger side sounds like possibly the water pump. I THINK that this is a cross-mounted engine, with the drive belt on the passenger side. If so, it is almost certainly the water pump leaking. Get a flashlight and a small inspection mirror and search around under the water pump drive pulley for signs of water dripping. If no water is found there, it probably is not the pump. Have you checked the cooling fans for proper operation? Tested the temperature sender that controls the cooling fan?
Jun 04, 2012 | 1994 Plymouth Voyager
My car's fanbelt broken on high speed and I saw the temperature raised so I stopped immediately before it could overheat but then I saw the water leak out.After replacing the fanbelt I put Water in again...
You did well by shutting down quickly.
Why did the water come out when you stopped after the fan belt broke???
Residual engine heat. The engine has fiery explosions going on in the cylinders. Very hot.
Antifreeze flowing through the water jackets of the engine carry this heat away. Fan belt breaks, water pump stops pumping this very hot coolant away, engine temp goes up.
Thus the coolant temp rises enough to boil and push the coolant past the pressurized radiator cap out the overflow onto the ground.
I would recommend a fifty fifty blend of antifreeze and water for coolant. It just cools better.
Not seeing any leaks is very good. Smart thinking on your part saved you money.
Wayne
Feb 13, 2011 | Mazda MX-6 Cars & Trucks
I have a Bosch tankless propane water heater 125fx. Yes, I know it's ****, we replaced the igniter switch last year. Then struggled with ordering parts to repair a water leak. During the leak, it was...
There is likely an onboard relay stuck in the open position.
This is a gas appliance and should be serviced by an authorized BOSCH repair center to avoid potential catastrophe.
Thanks!!
Aug 06, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Water is leaking from inside of the refrigerator and we are constantly wiping off water from the floor. The icemaker isn't working.
I don't mean to sound sarcastic here but have you lifted the icemaker arm to see if the leaks stops? If it does the icemaker water inlet thru tube from the back of the unit is somehow wither not alightned with the icemaker inlet or the icemaker itself is letting water go though it.
Having said that if your unit is all froze up in the back of your freeze and the fan can no longer circulate air properly that too can cause bot the icemaker to stop working and a leak if the upper cabinet drain is iced over.
You can make sure it is not an icing / "not defrosting" problem by unplugging the unit and placing a fan blowing into the freezer section for at least 2 hours. Mind you this will only add to your water messes but it is a must do so have the mop and rags ready when you do this. Once you have done the fan routine plug it back in and see if after 8 or more hours that the leaks stop and the icemaker functions.
If after all of this it does funtion normally then you unit is not defrosting and will need to have the defrosting system checked out. NOTE after a few days (3 - 6) it most likely will start freezing up again if there is in fact a defrost problem and it will repeat the same antics in the past. Hope this was helpful.
Jan 18, 2010 | Refrigerators
My 1993 corvette over heats at every stop and in slow traffic iam affraid to drive any where fear of my car over heating
This could be cause by a variety of problems such as low coolant, bad water pump, head gasket leak, manifold leak, malfunctioning fan clutch, broken electric fan, etc etc.
If you have an electric fan, it is designed to turn on triggered by a temperature sensor located near your top rad hose mounting on the intake manifold. If this sensor is broke you will over heat without the fan kicking in at stops. Same with a clutched fan. Could be not moving enough air at a stop.
Check your coolant levels and let your vehicle run while watching to be sure your fan kicks in. Keep your fingers away from it while running. It can start up anytime. If all is well, you may have a plugged rad or restricted rad.
Jun 30, 2009 | 1993 Chevrolet Corvette
Jeep cherokee ran hot and now the fan has stopped. What do I need to fix the problem? I put water in the radiator it started bubbling water and leaking water from bottom of the radiator. I put a stop a...
You have cooked the engine, you can try replacing the radiator and the sending unit for the fan but you most likely destroyed both. unhook the fan and try it. if it does not bubble after 3 minutes then you may be ok but if if shoots water out of the cap then your thermostat is bad or you have a blown head gasket.
Jun 13, 2009 | 1999 Jeep Grand Cherokee
Diagnosing a blower that began ticking and then stopped
yes i am havin the same trouble but i have had outside water come in through my fan motor there is a hole in the bottom of the fan houseing and the water comes through there i am now waiting for my fan to stop working all togather and then i will replace it but not before i find the water leak
Aug 11, 2008 | 2006 Chevrolet HHR
93 Celica getting Hot
Sounds like your water pump may be going out.If the fan is mounted on the water pump,grab the fan on each side and try to wiggle it.If it moves side to side any its bad.
Jul 11, 2008 | 1993 Toyota Celica
Overheating
1. start the engine and leave the radiator cap open.
2. put a cardboard cover or a rug in the front of you radiator.
3. let it runs 20 minutes or more, see if it is overheated and see the water or coolant in the radiator circulated or not. If not, as soon as you have already changed water pump. thermostate and check the hoses, no leak, I think your radiator was blocked.
Did you put stop leak before?
Jun 17, 2008 | 1995 Toyota Camry
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
53 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
