Hunter Fan Company 5/1/1 Programmable Thermostat Logo
Anonymous Posted on Apr 14, 2010
Burning smell when lights are on
3 of the four 40 watt bulbs in the fan unit were burnt out and were replaced. Immediately after i noticed a burning smell like electrical shorting so I turned off the lights. What could be the problem here?
  • Anonymous Apr 15, 2010
    Sorry, I should have mentioned the fan was not operating when smell occurred,
Anonymous
Level 3:
  • Master 10,319 Answers
  • Posted on Apr 15, 2010
Anonymous
Master
Level 3:
Answers
10319
Questions
5
Helped
3075667
Points
30576
If the smell is gone 24 hours after the lights were turned off, turn on the fan & leave the lights off. Check for the burning order again. If you can smell it replace the fan. It will be the armature shorting out in the fans motor
2answers
Hunter-ceiling-fan light wont work
Make sure your contact in the socket is touching the bulb.
Mar 27, 2014 • Dryers
I have a Hunter fan that's about 1.5 years old, installed by pros when house was built, and no previous problems with the fan. Fan has wall switch for lights and wall switch for fan. A few days ago...
All is well with your fan. Light bulbs sometimes will blow with a surge of power. This happens to everyone. If you feel uncomfortable with the 60 watt go for 40 watt. It will be less bright however. No need to worry about the fixture catching on fire
Blower motor resistor burning out
Sounds like you are drawing too many amps through the circuit. Window defoggers draw a lot of power which could be the culprit and it tied into the circuit. Unless you are good with schematics and vehicle wiring, it's difficult to narrow it down to what it could be.
1998 Buick Century w/ manual control, smelled burning odor and blower motor quit working. Control Module?
blower resistor is common to burn causeing smell. check with dealer, there may be a campain on this problem. if not. replace resistor and harness (pig tail) and blower motor..
3helpful
2answers
Hampton Bay Ceiling Fan Plastic Burning Smell
I think you have already figured out what the problem most likely is; 60 watt bulbs. Down-size the wattage or install 'energy saver' bulbs if they will fit the application. Instead of counting on these units for extra lighting, perhaps think about Track lighting to fill in those ares that need more but subtle light.
Good luck. :)
Sparks, noise and burning smell
If it is burning and arcing at the antenna, it is probably arcing in the wave guide area. Probably will have to replace unit. I have had some success by removing the antenna, sanding and repainting the burnt areas of the cavity and sanding off any burnt marks on the antenna. Need to look at top of mag to see if also arcing there too.
Burning smell
.. any heat element like bulb must be installed exactly and that means its wattage, voltage and physical characteristics.. and also make sure that you have replaced Fan blowers and making it sure that it runs properly when the unit is on. as it was said also make sure that you do check the light that travels thru lenses and filters that is not block by dirt, cables or any other foreign materials.
Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Top Hunter Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
