I have a hunter lemoyne ceiling fan. One of the light bulbs popped and since then neither the lights nor the fan has worked.
Can it be repaired?
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
if the battery's are good then you broke it and you have to order a new one which you can do by calling the place that you got the fan from tell them what kind of fan you have and let them know that you nead a new remote and they will be able to help you do that.
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
SOURCE: HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jerry_612d8419f8984578
