20 Most Recent Hunter 23852 Classic Original Ceiling Fan Questions & Answers
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Hunter 23852... | Answered on Nov 26, 2018
Go to home depot or lowes,they will have it.
Hunter 23852... | Answered on Sep 30, 2017
You cannot do any lubrication on the unit. They are sealed.
Hunter 23852... | Answered on Jan 09, 2015
Most hunter fan don't require lubrication, if you hear a grinding noise I would check the balance of the fan, if your hearing a grinding, and its not caused by being out of balance, then I would replace fan
How did you change speeds? Remote, pull chain or wall switch.
[email protected]
Hunter 23852... | Answered on Oct 01, 2014
You need to put some Hunter oil then push the blades around by hand to get the bearings lubed. Then check oil level and add more oil if necessary.
Hunter 23852... | Answered on Sep 26, 2014
If you have a volt ohm meter you can test, the fan/light itself to see if there is a short circuit from the hot wire to ground or to the neutral. If there is a light hook up do the same for it. You might want to try just the light or just the motor connections to eliminate the bad circuit or faulty wiring. In some homes you will find that you have 2 hot wires, one switched and one not switched so watch for that because you could be connecting 2 hot wires together which will trip a ckt. breaker. if you are sure that you have proper wiring not, skinned or anything and the motor does trip the breaker then you have your solution.
Hunter 23852... | Answered on May 14, 2014
For what??
Hunter 23852... | Answered on Mar 28, 2014
Looks like you already found it, (23852), if you have a brown Original. Usually the labels are on the top of the motor housing. Also might be etched into the metal name plate on the side of the motor.
Hunter 23852... | Answered on Mar 14, 2014
There is a chance is says on another light bulb,a little tag with a number.
Hunter 23852... | Answered on Mar 09, 2014
If the oil is OK then check to see if it has a capacitor that might be going bad.
Hunter 23852... | Answered on Dec 31, 2013
Yes. Call 1-888-830-1326
Hunter 23852... | Answered on Dec 26, 2013
Hunter 23852 Classic Original Ceiling Fan Logo
74 questions posted
Top Hunter Dryers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hunter Dryers
  • Hunter Dryers
Most Popular Question
hunter origional
  • Dryers
