Question about MTX Thunder 3401 Car Audio Amplifier
MTX Thunder 3401 not responding. Lit but no sound.
Hi
I have the following installation :
Pioneer Avic X3BT head unit/GPS
Pioneer CDP 620 cd Changer
Ipod cable
MTX Thunder 3401 amplifier
MB Quart 284 subwoofer (open).
Yesterday suddenly, while I was listening to "Plastic beach" from Gorillaz, I increased the volume and ..no more bass coming out of the sub.
I checked : No fuses are blown (2 on the amplifier are ok, one from the battery connection is ok, the amplifier lits but it has no sound coming out.
I tried to change the output connection to the sub (in case a channel would be dead : nothing). I opened the sub : it is perfect.
I unmounted the head unit and checked the sb RCA's output : well connected. All the wires are ok. The RCA cable is hot so it seems the signal arrives to the amp. I also took an ipod and connected it directly to the rca input on the amplifier. nothing.
the amp's power seems to work, it's hot (normal temperature, I tried the prizm effects to see if any signal made the display blink, but no luck there.
I think something like transistors on the amp went down. any ideas ?
Posted by news2mj on
Anonymous
    New Friend:
    Problem Solver:
  • 6 Answers
Turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Posted on Apr 06, 2010
Pioneer AVIC-D3 In-Dash GPS Navigation System with DVD Player
the d3 will play dvds, and you can buy a cd changer for it seperately.
Apr 01, 2009 | Pioneer AVIC-D3 Car DVD Player
Tip
Pioneer AVIC N5 Installation Manual Have you misplaced your Pioneer AVIC N5...
Have you misplaced your Pioneer AVIC N5 GPS Multimedia System Installation Manual?
Would you like a digial, searchable, pdf version of the Pioneer AVIC N5 GPS Multimedia System Installation Guide?
Follow this link to download a pdf version of the installation manual.
I hope that helps.
on Apr 14, 2010 | Pioneer AVIC-N5 In-Dash DVD Multimedia...
Hello, I have the pioneer AVIC 700bt. When I plug my Ipod nano into the USB adapter on the head unit, the Ipod display comes up right away and it shows that it is playing but there is no sound coming...
You will need to be using the CD-IU230V cable for the iPod.
After connections, you will also need to follow these step:
Press "menu".
Press "settings"
Press " AV Settings"
Press "AV1 Input" multiple times until it says iPod.
You will now be able to hear the sound from the ipod when it is selected as a source.
Dec 26, 2008 | Pioneer AVIC-F700BT Car GPS Receiver
My mtx thunder 1501d car amp making noise in the subwoofers
This is common with pioneer head units, the rca jacks are not properly grounded and this lets engine noise come through the rcs cables. This thread explains a fix http://www.caraudio.com/forum/showthread.php?t=337644.
Nov 13, 2008 | MTX Thunder 1501D Car Audio Amplifier
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
Pioneer 5.1 dolby surround multichannel processor ?s
You will need extra amp(s) to run 5.1 surround sound using out IP-Bus at the brain to in IP-Bus at the processor and rca output to the multi channels amp(s) and control the surround mode which is automatically activate by the format of the disc. The IP-Bus cables is colored polarized at each end to inter connect all components. Just hook them in series follow the color you may add all the components you have. You can also down load wiring diagrams at pioneerelectronics.com. Goodluck.
Apr 16, 2008 | Pioneer AVIC-N2 Car DVD Player
Pioneer CDX_1280 12 Disc Changer
hi sounds like dirty laser, or dodgy disc.
check your cd for marks. you could try a cd cleaner disc. this may cause it
other wise its a new laser
Mark
Blue ICE
www.blueice-electronics.co.uk
Jan 04, 2008 | Pioneer CDX-P1280 12-Disc CD Changer
Connceting a pioneer cdx - p670 to avic x1 head unit
the changer is either incompatible or the changer wire has been intrnaly dammaged to much bending shorts them out as the wires are no more than alluminum foil enclosed in shrink wrap
Dec 28, 2007 | Pioneer GPS AVIC-X1 car radio
Pioneer avic x1
GPS has global coverage. I see your problem is sourcing the map of Australia because the x1 comes only with Europe maps on CD. there may be a possibility the S2 maps work on the x1. Try contacting Pioneer Australia http://www.pioneer.com.au/customerservice/
Sep 07, 2007 | Pioneer GPS AVIC-X1 car radio
MTX Thunder 3401 Car Audio Amplifier Logo
227 people viewed this question
Top MTX Car Audio & Video Experts
Marvin
Marvin
Rob Beech
Rick Wrieden
Rick Wrieden
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
