20 Most Recent MTX Thunder 3401 Car Audio Amplifier Questions & Answers
0answers
I installed a MTX Thunder 3401 with a PA sub.
You are def overheating, If the ohms rating of the subwoofer is too low it will cause this same thermal over heat. If you have 2ohms in sub and a 4 ohms stable amp, you will overheat. Check the ohms rating of the sub to make sure this is not the problem
2/3/2011 6:11:15 PM • MTX Thunder 3401... • Answered on Feb 03, 2011
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
4/6/2010 5:44:36 AM • MTX Thunder 3401... • Answered on Apr 06, 2010
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
9/30/2008 6:45:09 PM • MTX Thunder 3401... • Answered on Sep 30, 2008
2answers
Fuses
Check the ohm measurement of the speakers make sure they are about the rated ohms.Check them UNHOOKED from the amp. (Useually 4 ohms.)
Try different subs.
7/17/2008 7:30:19 PM • MTX Thunder 3401... • Answered on Jul 17, 2008
My amp
Kind of a vague problem description, can you be a little bit more specific. What problems you are experiencing, how many speakers/subs were you powering with it, does it show that it has power, did you check the fuses?
7/17/2008 6:16:10 PM • MTX Thunder 3401... • Answered on Jul 17, 2008
How to repair a mtx thunder 240 amp
If you have to ask, take it to a repair shop.
12/28/2020 5:26:39 PM • MTX Car Audio &... • Answered on Dec 28, 2020
Mtx 8100d, how do I hook up ?
power to-battery plus ground;; remote''
11/5/2019 3:28:19 AM • MTX Car Audio &... • Answered on Nov 05, 2019
What are the red lights on my mtx tna251 amplifier
THE GREEN LIGHT SHOULD SHOW WHEN AMP IS POWER UP AN RED WHEN IN PROTECTION MODE
9/12/2019 4:23:17 AM • MTX Car Audio &... • Answered on Sep 12, 2019
Where can i get a Manual for a mtx 600 watt terminator amplifier its a tna251
Try eBay Often available there from private sellers
8/25/2019 6:45:34 PM • MTX Car Audio &... • Answered on Aug 25, 2019
I have a mtx tunder series 942 when you hook it up the red light comes on I have the best wire and have checked everything the amp is old school it does have a fuse on it I have one on my power line pls help!!!!!
I was having a similar issue. I checked every wire from the battery to stereo to amp, checked the ground, pulled the stereo to double check the wiring was all correct. Everything seemed good so I thought it had to be my battery not putting out enough power. Tested it and it was good. What it turned out to be was the connection from the power cord to the battery. It had a tiny bit of built up corrosion that was making the amp go into protect mode. Cleaned it up and hooked it back up and has been golden since.
The link attached is pretty straight up on what you need to check for different circumstances. I'm guessing it's a low voltage issue. Good luck
8/23/2019 5:53:57 AM • MTX Car Audio &... • Answered on Aug 23, 2019
I have 3 x 10 inch MTX RT10XDS subs in an enclosure, with a pair of 6x9s 500w pmpo and 2 mids.Whats the best way to wire to the Lightning Audio Strike amp S2.500.4???
you have to first note the ohm load the amp can handle and wire the speaker that ther amp can handle
5/13/2019 1:14:24 AM • MTX Car Audio &... • Answered on May 13, 2019
Okay mtx 4501 lights up no sound
Check the wiring 1st then go down the line...Check speaker connections..Look at your power,ground and remote wire hook up
10/18/2018 5:03:22 AM • MTX Car Audio &... • Answered on Oct 18, 2018
MTX Thunder 3401 Car Audio Amplifier Logo
10 questions posted
Top MTX Car Audio & Video Experts
Pierre Laplante
Steve Sweetleaf
Steve Sweetleaf
 Francisco Mauricio...
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • MTX Car Audio & Video
Most Popular Question
installed mtx thunder 3401 pa sub
  • Car Audio & Video
