20 Most Recent MTX Ford Explorer/Mercury Mountaineer/Mazda Navajo 1991-2001 Thunderform Loaded with 10 Inch Woofer and ... Car Speaker Questions & Answers
this is the same model that i was asked about earlier. i cant do anything about this though. only ford can help you with this. thanks for asking though.
MTX Ford... • Answered on Aug 16, 2014
usually under the hood a lable somewhere or on the package with the new belt
MTX Ford... • Answered on Jan 20, 2014
first try replacing the bulbs in the corners and see if they work with new bulbs
MTX Ford... • Answered on Oct 23, 2013
i suggest you contact ford about this. i cant seem to locate either of the codes for this model. sorry for the delay.
MTX Ford... • Answered on Aug 25, 2013
Ends up being a broken wire(ground) in the rubber boot between door and frame. I carefullly removed door panel, pinched the ends of the boot and slid it back into door. And there it was...a broken black wire. Spliced in a new piece of wire, reassembled everything else. Everything works like it should. It's really not that hard just take your time. Also before I started I disconnected the battery as a precaution. Goodluck.
MTX Ford... • Answered on May 26, 2013
That car has a factory amplified system,,,,,BEST and EASIEST solution is go to METRAONLINE.COM,enter vehicle information to buy amp interface harness.no more than $50.00 at a stereo shop. If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
MTX Ford... • Answered on Feb 20, 2013
You may download a copy of the manual here. The wiring diagram is on page 19.
MTX Ford... • Answered on Nov 30, 2012
Check/change the #4 plug. Make sure the gap is right, ceramic not broken, and that the plug wire is on correctly.(both ends) Did you use dielectric gel when you installed the plugs? Good idea to use it.
MTX Ford... • Answered on Apr 02, 2010
the switches for these vehicles are in the latch and they seize up from time to time. you will have to spray some penetrating oil into the dor and rapidly close and open the door hard to try and fix it. if that doesn't work then you will have to figure out which door it is and replace to latch. note if key is on, the dash will make a tone everytime you open and close door. so the door that doesn't chime that is the door with the issue.
MTX Ford... • Answered on Aug 28, 2009
I would reccomend checking the fuel pump for starters, it maybe getting "stuck."
MTX Ford... • Answered on Aug 01, 2009
your sensor in the door lamb is bad or its the sensor for them
MTX Ford... • Answered on Jul 31, 2009
do you have any subwoofers or a loud sound system in your car? sound to me like inner damage due to vibrations from extreme sounds?
MTX Ford... • Answered on Jul 03, 2009
Oil filter might be clogged or your engine could be getting too much gas...check your spark plugs too...
MTX Ford... • Answered on Jun 08, 2009
Car Audio & Video Logo
Popular Tags
50 questions posted
Top MTX Car Audio & Video Experts
Pierre Laplante
Steve Sweetleaf
Steve Sweetleaf
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • MTX Car Audio & Video
Most Popular Question
kenwood kdc 119 wiring diagram
  • Car Audio & Video
