Frigidaire built in dishwasher # FDB1502RGC2 - 2 years old
large portions of the upper rack do not clean dishes- looks like no water is coming in contact- water jets are clear- nothing is blocking the water spouts-seems to spin as usual- usually extremely quiet, now a fairly soft. but obvious motor sound is audible - dishes on bottom rack are fine
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it
