Hi
First make sure that nothing is blocking the drain pump
assembly located inside the lower front panel of the dishwasher. If the issue
returns after its cleaned then try to reset the dishwasher control by pressing
the HEATED DRY button and hold it for 15 seconds, if its still not resolved
then it means that the control board has gone bad and should be replaced. Hope
this helps...please post back for further assistance.
Daniel
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If not the pump must be checked for clogging.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
26 questions posted
485 Questions
214 Questions
206 Questions
161 Questions
175 Questions
