I have a Hayward 1 HP pool pump. I have to replace the start capacitor. I have not been able to locate a wiring diagram to direct me in the connection of the two yellow and one red/white leads.
Hi ...the two yellow go on one side of the cap and the red /white go on the other.. like two on the negative side of a battery and one on the pos .. your pool pump repair guy longwood fl
the 2 yellows go on the same post (hooked together)
jay i just replaced a sta-rite 1hp. motor with a marathon it had 1 red -LI-oneblue L2 one green or nuetral in the middle.motor wont start it is set for 220v operation on the motor[switch] took it back same thing with other one....wen to electronic college the run cap only has 2 red wires on it on opposite sides 1 top 1 bottom is there a third jumper wire missing to energize the cap no schematic from pool pump supplier contacted the company but no answer or is the inter matic clock circuit out on one leg?i hear the clock running but a guy there told me you can sometimes get a false reading on one leg due to clock circuit....thanx
