20 Most Recent Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15 Questions & Answers
it is possible that the knob was overtightened. check the slipping knob to see if there is a crack in the shaft. the other option is that it is stripped.
either way, it will not be considered normal wear but you should be able to find a replacement knob at your local store
Hayward 1 12 Hp... | Answered on Mar 16, 2016
Inside pump is a difram , it most likely is stuck, some times if you shut off pump, turn back on a few times it might release itself, but most likely needs to be replaced. Let me know, mike from fixya.com
Hayward 1 12 Hp... | Answered on Oct 29, 2014
Why not google this question?
So many hits, even with diagrams.
Hayward 1 12 Hp... | Answered on Jul 08, 2014
If you are still having problems please post more info. Does circulation seem normal at pool inlet returns? Do you have full prime at pump?
Hayward 1 12 Hp... | Answered on May 04, 2014
take a picture or two of your pump and wiring and go to your local ace hardware. so yes you can but it takes a high amp switch, and some extra fittings and a box to hold the switch. jay
Hayward 1 12 Hp... | Answered on Feb 27, 2014
no is not right if you have replaced the motor on the label can tell you what wires to chnage to meke it run in the right diretion
Hayward 1 12 Hp... | Answered on Oct 06, 2013
CHECK TO SEE IF THE IMPELLER IF GOT TRASH IN IT..IS THE STRAINER BASKET CRACKED ? IF SO REPLACE IT ...AND HEAR IS HOW THIS PUMP COMES APART
Hayward 1 12 Hp... | Answered on Apr 15, 2013
Fill the pump pot with water and make sure the lid o-ring is lubed and in good condition. Replace the lid and turn the pump on. If it still won't prime make sure the water in the pool is high enough. Otherwise you make have a suction side leak. Any breech in the plumbing will allow air to enter the water stream. If the breech is big enough no water will be drawn to the pump.
Hayward 1 12 Hp... | Answered on Dec 19, 2012
Do you mean no water pumping?
If so it's likely that your impeller is broken. The impeller screws onto the motor shaft.
Hayward 1 12 Hp... | Answered on Oct 18, 2012
Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15 Logo
57 questions posted
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Hayward Pool & Spa
  • Hayward Pool & Spa
Most Popular Question
want wiring diagram flo master sp2
  • Pool & Spa
