20 Most Recent AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen Questions & Answers
To get to the Impeller you need to remove a series of bolts, or a large clamp, that holds the two halves of the pump together. Once you do that, if their is a diffuser (housing that goes over the impeller), remove it. To remove the impeller, you need to lock the motor shaft. You can do this a couple different ways depending on the motor. There will either be a small cap that grants access to the motor shaft on the back of the motor, or you remove a larger housing that grants access to the wiring and other components in the back of the motor. If it's the small cap, then you can hold the shaft with a wrench. If it's the larger housing, then you can slip a wrench (probably 7/16") under the thermal overload switch and onto the shaft to lock it in place. Now you can unscrew the impeller. Check to see if the impeller has a screw in the center. If so remove this first. It will be reverse thread. The impeller should spin off counter clockwise. If the impeller is very tight, be careful not to damage it. If you don't have an impeller wrench, I strap wrench, or very large locking pliers with a rag around the impeller works well. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
AO Smith Pool... | Answered on Nov 22, 2018
The two wires are interchangeable.
AO Smith Pool... | Answered on Nov 12, 2017
check for a re-set button somewhere on the motor housing.
AO Smith Pool... | Answered on Aug 16, 2017
Are these the wires that come from a power source to the motor?
Which are called Line wires.
if these are Not Line wires, then they are the motors internal wires, and you could be out of luck? You will need the manufacturers wiring diagram.
If they are Line wires, then simply... Get a multimeter, turn power on, and test each wire to ground. This will tell you if and which each wires is line/hot or not.
AO Smith Pool... | Answered on Jun 07, 2015
try spinning the shaft by hand if it sounds gritty yes
AO Smith Pool... | Answered on May 14, 2015
What's the make and model.
Sorry, but info you provided is of no value.
Need specifics of complete pump
AO Smith Pool... | Answered on May 11, 2015
Oil?
you can't oil a pool pump.
NO Lubrication available!
They have 'Sealed' bearings.
So if the motor is loud, they (bearings) either need to be replaced, or the motor needs replaced.
AO Smith Pool... | Answered on May 10, 2015
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
Popular Tags
103 questions posted
Top AO Smith Pool & Spa Experts
john h
David Spradling
David Spradling
MODERATOR WORLD
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
AO Smith Pool & Spa
  • AO Smith Pool & Spa
Most Popular Question
new pool pump motor governor keeps
  • Pool & Spa
