Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
2:
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
rate please !
