Dryers Logo
Posted on Mar 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Goes on works about 10 minutes. stop.try to turn
Goes on works about 10 minutes. stops.try to turn on , won't work..wait ten minutes, works for abot 5 minutes. Gallery Series approx .12 years old. Electric. does it pay to service & try to fix orb get new one
Anonymous
Level 3:
  • Master 619 Answers
  • Posted on Mar 20, 2010
Anonymous
Master
Level 3:
Answers
619
Questions
0
Helped
143510
Points
1691
Problem is the motor is going bad. Sometimes the motor can almost cost as much as a new dryer. An excellent little dryer that will last and work ghood for you is Roper, made by whirlpool. Any Lowes store has these. Hope this helps.
2009 chevy traverse wont start after hooking amp up car was fine
OK. you had the battery disconnected. Here is what you do. Turn on the key. The security light will begin to flash. Wait (about 10 minutes) with the key in the ON position. The security light will stop flashing. TURN OFF the key. Then, turn on the key and start the car. Security system is supposed to prevent theft for a 10 minute delay. This usually discourages any thief. This will work, You just need to be patient with the 10 minutes. It seems like an hour when you wait ten minutes for that security light to stop flashing.
My Saturn vue 2002 does not want to work because it just starts but, than it stops like working than I just wait 10 min and it starts to work but I don't know whats going on?
It's the security system. You'll notice when you try and start it, if the problem is happening, the security light on the dash will be blinking. The remote won't reset the security system. You have to wait the full ten minutes and it can be very annoying. I think it has something to do with the driver's seatbelt switch. There is a double wire under the seat that goes to the seat belt buckle. Mine was cut and taped back together. I think the switch in the buckle gets dirty. Try squirting some WD-40 in the buckle. Also try to not be in too much of a hurry when you jump in and start it because that's when it happens, then you're gonna be ten minutes late anyway. I just get in mine, sit down, and wait a second before I try to start it. Haven't had the problem for some time now.
Reset passlock code
Is your Impala a 2000, 2001, or 2002? This seems to be a common problem in those model years...much like its predecessor the GM VATS (Vehicle Anti-Theft System). While the VATS had a permanent (albeit unapproved) solution, no suck workaround appears to be available for the Passlock system. Some websites offer a correction "module" that looks to be a hit-or-miss solution. I did find the following procedure on a forum, and it seems to be reliable. Here goes:
If your car has been sitting while you were at work or home or in the store, and you are coming out to leave, follow steps 1-6.
If you just had the SECURITY SYSTEM lock you out of the ignition system, you will have to wait the 10 minutes for it to reset and allow the ignition control module to interact with the system. Once the 10 minutes have passed from the ACTIVE SECURITY STATUS, follow steps 1-6. Do not try to shortcut this as it wont work.
If it is raining, you can close your door, just not all the way. Close it all the way and open the door latch without pushing the door open. This will keep you dry.
+++++STEPS+++++ 1.) OPEN YOUR DRIVERS DOOR AND SIT DOWN. 2.) PLACE KEY IN IGNITION, WAIT FOR CHIME. (3 seconds is what I usually wait) 3.) TURN IGNITION 1 CLICK RIGHT (TO THE ACC POSITION) AND STOP! Do not continue to ON and START yet. WAIT ATLEAST 5 SECONDS 4.) AFTER 5 seconds has passed, TURN KEY TO ON and STOP, DO NOT CONTINUE TO START YET! 5.) WAIT AND WATCH. With your drivers door open, here is what you will see and hear = Your notification will signal DOOR ADJAR, then the BATTERY light, then the SECURITY light, during which you will hear the chime sound as if you just started the car. 6.) AFTER YOU SEE THE SECURITY light switch back to DOOR ADJAR or Battery, and after the CHIME has stopped, you can turn the key to start and voila!
It has worked every time for me and 5 of my friends. This whole process takes about 20-30 seconds, but it sure as hell beats 30 minutes, as GM refuses to compensate my time lost to their vehicle\'s design flaws.
RECAP: 1.) Open driver door, sit down 2.) Insert key in ignition, wait for chime 3.) Once chime starts wait 3 seconds 4.) Turn key to ACC position WAIT atleast 5 seconds 5.) After 5 seconds turn key to the ON postion and wait for the security light to switch back to Battery or DOOR adjar, and the chime to stop (Do not try to START if the chime is still sounding) 6.) Once chime stops and Security light has passed, You may now complete the turn to START and it will start.
Note: This is not a permanent workaround, but it will buy you some time, I can almost guarantee it will work for most if not all people, almost all the time.
3answers
2004 Alero wont start!
sound like theft security problem.when you try ten minutes did you leave ignition switch on position for ten minutes until the security light turn off then turn off ignition switch for 5 seconds then try starting vechicle.when you do 10 minute trick security light has to turn off or disappear when you see security light go off turn off switch 5 seconds then try starting vechicle.
Electric blanket flashing f won't stop sunbeam
Hello vinrocof - Please try resetting the unit by either unplugging it or flipping the breaker off. Wait approximately ten minutes and turn the unit back on. Try setting the time and if it proves to be ineffective, the unit may possibly have a faulty EOC, defective wiring harness or damaged cord. I would suggest contacting a professional to move forward accurately.
1helpful
Hello everyone I have a 2001 dodge stratus coupe 3.0l thats im have problems with it. Is crank works and then stop the car it wont work wait ten minutes then it works any idea what it could be ????
Difficult to follow your english, but I think you are saying the engine dies and you have to wait 10 minutes to restart it.
Someone would need to check for spark at the plugs and fuel pressure at the injectors when it won't start to proceed.
Programing ignition key for 2000 grand am security light comes on and the car will not start for 10 to 15 minutes.
Turn the key on and wait for the security light to stop blinking (may take about ten minutes). Then turn the key off and wait for at least one minute. Then try to start. That should program the key chip.
4helpful
3answers
Dont know how to reset or bypass gm theft system car is not starting .It tries and quits.
this is one way to reset it :
first make sure the battery is fully charged , then do the following:
key in the ignition but do not crank the motor, just leave it at the
ignition mode for ten minutes ,then turn it off POSITION for 5 seconds then REPEAT again 2 more times. at the 3 rd time youre gonna notice the ANTI THEFT light on dash to blink. when doing the last step , remove key , inserted again and turn on motor , good luck , AJ
Dryer won/t work
Hello chuhunghuang
Welcome
You said, your control lock light is lit. dryer will not work
Let me know how it goes!
Try ,
Pressing STOP/CANCEL to clear the display.
If this does not work.
pull the plug for 5 minutes or if you can't reach the plug you can turn the power off form th breaker for 5 minutes.
This should reset the system.
Bless You huuum
Please leave a rating before you leave the site!
2answers
04 chevy malibu
If the light has not stop blinking when you wait ten minutes then it is not going to crank. My does it a lot but after 10 minutes the light has stopped blinking. I think that the ignition switch needs replacing or maybe just the key is worn out. I think when anybody goes to fix this GM problem it is a guessing game.
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
