Abit NF-M2S Motherboard Logo
Posted on Mar 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was on the internet, and went in the other room. Suddenly my computer started beeping. Three second beep, 3 sec pause, 3 sec booe, 3 sec pause, continually until i shut it down. When I turned it back on, it beeped the same way. What part of the computer went bad?
Anonymous
Level 3:
  • Master 797 Answers
  • Posted on Mar 12, 2010
Anonymous
Master
Level 3:
Answers
797
Questions
Helped
191176
Points
2336
Sounds like memory. If you have more than one stick of memory, try using 1 stick at a time and see if it will boot.
My Juki gives 3 beeps when I start up
https://www.youtube.com/watch?v=Mw0iFamTYMs
https://www.youtube.com/watch?v=CakM3FWKmGc
Three beeps that repeat after a pause and occur when you power on your computer indicate a problem with the system memory. Three beeps that play and then stop as the computer starts successfully mean that the BIOS was restored.
https://smallbusiness.chron.com/three-consecutive-beeps-mean-computer-79697.html
6helpful
3answers
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
2helpful
How can i fix my IBM ThinkPad T22 2647. it produce 3 simultaniuos beep sounds lcd is black out.
This is a list of ThinkPad Beep codes.
It appears you have a memory or motherboard problem, most likely a RAM problem. Try reseating the RAM modules, if this doesn't work, then remove the RAM and take them to your friendly computer repair shop to get them to test the RAM modules for you. If the RAM is faulty them replace.
Beep symptoms
Symptom or error
Service part or action, in sequence
One beep and a blank, unreadable, or flashing LCD.
  1. Reseat the LCD connector
  2. LCD assembly
  3. External CRT
  4. System board
One long and two short beeps, and a blank or unreadable LCD.
  1. System board
  2. LCD assembly
  3. DIMM
Two short beeps with error codes.
POST error. See Numeric error codes for more help.
Two short beeps and a blank screen.
  1. System board
  2. DIMM
Three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
One short beep, pause, three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
1helpful
My computer wont exit reset status mode!
I need some help. I just bought a new hp netbook, but when I try to turn it on.....all I get is a small box saying: When trying to update a password, this indicates that the value provided as the current password is not correct.
What does this mean, I tried to reboot and everything but nothing happens, the computer keep restarting and I keep getting the same small box.
Please need some advice and help
3helpful
2answers
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
BIOS beep codes on packard bell home pc
You need to check your RAM, make sure it is seated properly.. this should fix the problem!
Top Abit Computers & Internet Experts
ExpressFiX
ExpressFiX
JTR44
Level 1 Expert
Grand Canyon Tech
Grand Canyon Tech
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
