We are using this TYAN S5220 mother board at CT Scan machine of GE Healthcare .
Don't see that one in the list in manual
http://www.tyan.com/manuals/m_s5220_110.pdf
SOURCE: d101ggc
my motherboard Intel D101GGC has no display and no beep also i change the memory but they same problem i encountered..what are the solution i applied in this problem...
SOURCE: Three "beeps" before startup, but no "answer" then...
Beep Codes:
click this link: http://www.intel.com/support/motherboards/desktop/sb/cs-010249.htm
SOURCE: abit beep codes?
Here is a good discussion on the ABIT Beep codes. See if this helps you.
http://www.ocforums.com/showthread.php?t=218664
Good Luck,
Paul
SOURCE: Post Error Beep Codes for System Board
Beep codes are here
http://support.gateway.com/s/Servers/COMPO/MOTHERBD/WME859199/WME859199faq2.shtml
SOURCE: No display .. getting three short beeps, pause,
It's the sound produced by motherboard stating that motherboard is not able to detect the RAM,open the laptop and remove the RAM and clean with a white paper slowly and insert it properly.check it solve your problem otherwise if you have another RAM slot available then try that too. if none work replace with a NEW RAM this will solve your problem
let me know if it's helpful to you
