20 Most Recent Packard Bell Easy One Silver 2101 Notebook Questions & Answers
you will have to start up the internet and go to the tool tap at the top and go to internet options and then connections and make sure that never dail a connection is selected. hope this helps
Packard Bell... | Answered on Sep 20, 2017
Wow. No, it should not take that long to do a restore. The problem is stopping the restore MAY brick the system. Your problem seems to have started with the ParetoLogic. It seems this program will not uninstall properly unless you kill it in task manager first. http://support.paretologic.com/customer/en/portal/articles/2222917-how-to-uninstall-paretologic-internet-security-
This is strange because most security program cannot be disabled from task manager. Once you installed AVG you had 2 antivirus running at the same time - if not 3, Norton has been known to not uninstall cleanly. They even make a special removal tool. Download and run the Norton Remove and Reinstall tool
If the restore finishes - great, if it doesn't and you have to shut down the computer, it should roll back when you reboot. That puts you back to where you started so follow the instructions to remove Paretologic, run the Norton Removal tool and just to be sure, run the AVG Removal tool because the install might have been corrupted. http://www.avg.com/ca-en/utilities
Packard Bell... | Answered on Mar 05, 2017
Look at the keys on your keypad. Do you see one that may have a webcam symbol on it? If so try holding down on the Fn key, and pressing down on that key at the same time.
If this information does not help, then when Windows is loaded, and running, press the Start key, hover your mouse cursor on All Programs, go to the right, hover on >Packard Bell>drop down to >Security and Support>and then Packard Bell InfoCentre.
Click on Packard Bell InfoCentre. On this screen look at the icons across the top. Click on the icon all the way to the right. -> Guides
It has an icon of a book in it.
Look for Webcam.
Packard Bell... | Answered on Feb 23, 2015
Seems like your keyboard might have gone so you can order a online a replacment keyboard to fix it yourself or better take it to some hardware shop to get this thing fixed.
Packard Bell... | Answered on Nov 01, 2013
restart the computer HOLD the keys CTRL+f2 or esc and go to the recover the password and or introuce a new one.
God bless you
Packard Bell... | Answered on Jul 04, 2013
Only you or the previous owner have the HDD password.
my keyobard won't work on my packard bell laptop
Packard Bell... | Answered on Jun 05, 2013
Kindly check your spec as it doesn't contain built in WiFi however you can add external Wireless card
Good Luck
Packard Bell... | Answered on Mar 08, 2013
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
Packard Bell... | Answered on Feb 19, 2013
I think you should remove your Memory RAM at the back of the laptop and wipe the edges with a clean white sheet.you can locate this also using your manual
Put it back and lets notice the results..
But if the problem still exists then i think you should change the memory RAM with a good one..
Please let me get back to me and let me know the results..
Thanks
Packard Bell... | Answered on Oct 24, 2012
Did you turn the wireless switch on? Normally there is a switch either on the sides or the front of the laptop that you have to turn on. Sometimes it is a button at the top of the keyboard.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Packard Bell... | Answered on May 21, 2012
It is normally a function key (F1 thru F12) you press repeatedly once you hit the power button. F11 seems to be the most popular one.
Sometimes the recovery is listed in the program list. Click Start/Programs and see if you see any reference to recovery. It might be listed in one of the Asus Folders in the Program List.
You can always go to Asus site and download or view the manual. Look for Recovery in it.
Get onlineand got to www.google.com In the google search box type: "AsusSupport" (without the quotes). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals or Documents.
Packard Bell... | Answered on Apr 03, 2012
Hold the CTRL and ALT key and press the "UP" arrow key on the keyboard.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button and leave a short comment to let other people know how I help you. Have a good one!
Packard Bell... | Answered on Aug 06, 2011
Hi
have a look at the top row of keys to see if there is a key with a picture of a camera
if so press it or press FN+ that key or ALT + that key
or
go to control panel find scanners/camera and look for the web cam and press it
o
go to start
all programs
packard bell
user guide/info
and see if that shows you how to activate the web-cam
there are so many makes and models and they can all work in different ways
hope you can sort it
many thanks
Packard Bell... | Answered on Jun 14, 2011
go to the packard bell suport site and go to drivers and downloads and find your laptop model and you will see all your updated drivers
Packard Bell... | Answered on May 25, 2011
your installed operating system is not complete
format again your computer
Packard Bell... | Answered on Mar 26, 2011
To my knowledge there are no FREE wireless broadband solutions in the country. The least expensive is cricket (http://www.mycricket.com/broadband) which is as low as 40 dollars per month, but coverage is only in certain locations. Your laptop should have a built in wireless adapter which will allow you to access any wireless routers or wifi hotspots. If you have a wireless router at home you can use it to access the internet. If you need further assistance feel free to email me at [email protected]
Packard Bell... | Answered on Jan 13, 2011
Packard Bell Easy One Silver 2101 Notebook Logo
134 questions posted
Top Packard Bell Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Marvin
Marvin
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Packard Bell Computers & Internet
Most Popular Question
laptop runs slow
  • Computers & Internet
