1996 Ford F250 Crew Cab Logo
Posted on Mar 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change an exhaust manifold leak 7.5L - 1996 Ford F250 Crew Cab
Wayne Fellows
Level 2:
  • Ford Expert 262 Answers
  • Posted on Mar 11, 2010
Wayne Fellows
Ford Expert
Level 2:
Answers
262
Questions
Helped
246094
Points
802
Right-Hand
Removal
  1. Remove spark plug heat shield (12A406).
  1. Remove distributor to spark plug wires (12286) using Spark Plug Wire Remover T74P-6666-A.
    1. Disconnect muffler inlet pipe.
    1. If equipped with secondary air injection, disconnect the secondary air injection check valve tube (9B480).
    1. Remove attaching bolts and right exhaust manifold (9430).
    1. Inspect joint faces for signs fo exhaust leaks, cracks or any defect that would make exhaust manifold unfit for use
Left-Hand Removal
1. Remove oil level indicator tube (6754).
  1. Remove spark plug heat shield.
  1. Remove distributor to spark plug wires using Spark Plug Wire Remover T74P-6666-A.
  1. Disconnect EGR valve to exhaust manifold tube (9D477). If equipped with air injection, disconnect the secondary air injection check valve tube.
  1. Remove attaching bolts and exhaust manifold (9431).
  1. Inspect joint faces for signs of exhaust leaks, cracks or any defect that would make the exhaust manifold unfit for use.
Installation
  1. Clean mating surfaces of right exhaust manifold or left exhaust manifold and cylinder head (6049). Clean mounting flange of right exhaust manifold or left exhaust manifold and inlet pipe(s). Clean mounting surface for air injection tube or right exhaust manifold. Apply light film of Premium Long-Life Grease XG-1-C or -K or equivalent meeting Ford specification ESA-M1C75-B to right exhaust manifold or left exhaust manifold.
  1. Position right exhaust manifold or left exhaust manifold on cylinder head. Install attaching bolts and washers, starting at fourth bolt hole from front of each right exhaust manifold or left exhaust manifold. Tighten bolts to 34-47 Nm (25-35 lb-ft), working from center right to both ends.
    1. Position inlet pipes to right exhaust manifold or left exhaust manifold. Install attaching nuts and tighten to 34-47 Nm (25-35 lb-ft).
    1. Position the secondary air injection check valve tube and the secondary air injection tube gasket (9C435) at rear of right-hand exhaust manifold. Install attaching bolts and tighten to 19-25 Nm (14-18 lb-ft).
    1. Attach the secondary air injection manifold tube (9B449) to left-hand exhaust manifold fitting (located under EGR tube). Tighten nut to 30-40 Nm (22-30 lb-ft).
    1. Attach the secondary air injection check valve tube to rear of right-hand cylinder head. Tighten bolts to 75-85 Nm (56-62 lb-ft).
      1. Connect EGR valve to exhaust manifold tube to left exhaust manifold, if removed. Tighten nut to 53-72 Nm (39-53 lb-ft).
      1. Install spark plug heat shield and distributor to spark plug wires.
      1. Install oil level indicator tube to left exhaust manifold, if removed. Tighten nut to 13-24 Nm (10-18 lb-ft).
      2. Start engine (6007) and check for exhaust leaks.
how to change an exhaust manifold leak 7.5L - 28b39c6.gif"/uploads/images/28b39c6.gif" alt="28b39c6.gif" class="h_mi" />
Hope this helps you...WF †
Anonymous
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Mar 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
19
Questions
12
Helped
8126
Points
39
Also, I have a 5.0 in my truck and I needed to change my passenger side (which just so happens to be the tightest spot) and to make it alot easier, I took out the fender well and i got right in front of it! Saved alot of scrapes! Only downside is you have to unhook whatever is mounted on the fender well, but it usually is worth it.
1 Related Answer
Anonymous
  • 10 Answers
  • Posted on Dec 01, 2009
SOURCE: 95 f150 4.9L leaks from exhaust manifold with a
You might have a warped exhaust manifold, or head. You can check this with a straight edge and a feeler gauge. Also check for hairline cracks.
Is the carbon on the outside of the injectors, or on the inside? If it's on the inside then it could be from cheap gas. Do a fuel injector service to get them cleaned out.
If you had exhaust leaking into the intake manifold you would definitely know about it(backfire).
1helpful
Exaust intake leaking
It's exhaust manifold. There are two manifolds, the intake manifold in the valley between the cylinder heads, and the exhaust manifolds, one on each side of a v figured engine.
And, yes, a leak in the exhaust or the intake will make it run lean. If the leak is close to the engine, it can do harm to the valves, too. There is a gasket between the exhaust manifold and the engine block. Likewise, there is an intake manifold gasket between the intake manifold and the block.
Lifter noise
by changing the exhaust I take it that you removed the standard exhaust manifold and fitted extractors in instead. The noise may not be lifters but a exhaust leak form the exhaust not being fitted properly (gasket ) or just and gas noise as the exhaust valve opens that is normally silenced by a stock manifold.
Rough idle and blue smoke. change exhaust manifold because it was cracks know its missing and sputtering when i put in gear. changed egr valve before manifold.
blue smoke indicates either a bad transmission modulator valve,or a manifold leak{intake} i usually do this test for a bad or suspected bad intake manifold leak,light a cigarette and take it around the intake manifold and look for it to glow really bright for an intake leak,for an exhaust leak you can see it blow the embers away from it.just make sure there's no gas around to ignite.always make sure that a fire ext.is onsite! thank you for choosing fixya.com!
3helpful
3answers
Exhaust makes a loud tick when first started
usually an exhaust leak, at exhaust manifold to head, broken stud maybe. Use a piece of hose to your ear and listen at manifold.
WHERE TO LOOK FOR EXHAUST LEAK
There are several areas to check for possible exhaust leaks. i will list them below.
1. Exhaust manifold gaskets - This will be the most common area. There is a gasket that separates the block from the exhaust manifold. these gaskets can fail, thus, causing a exhaust leak at the manifold.
2. Lower manifold gasket(donut gasket) - This will be a possible leak spot as well. This small circular gasket is placed in between the upper exhaust pie and the lower side of the manifold. It basically separates the pipe from the exhaust manifold.
3. Exhaust pipe - The entire pipe can rust overtime, thus, creating small holes along the pipe structure. These holes will cause the exhaust to leak ,thus, filling the vehicle will moderate fumes and causing louder than normal engine sounds during revving.
4. Muffler - This component can also deteriorate to the point that it cannot filter out the noise. It will also cause leaks as well.
You will find the leak in one or all of the areas stated above in the list.
2helpful
Low pressure exhaust sensor faulty on passat 57
If you have low pressure in the exhaust manifold, then there would an exhuast leak somewhere from the exhaust manifold to the tail pipe. These leaks tend to get bigger over driving time. It may be the exhaust manifold gasket, or a crack in the manifold. Give a good listen for a sputtering sound. Part of the exhaust pipes have to be removed for access to the manifold. A good spray of PB breaker will help a lot with the bolts here.
Escaping gas is bad for the environment. This also causes gas to enter the manifold and make its way to the valves. The temperature of the incoming air is very cold compared to the combustion chamber and can cause damage the your valves by stressing them.
If you find no leak, then you may consider the sensor may be faulty or the leak is very small.
Good Luck.
1helpful
2answers
What repair is needed to stop exhaust manifold leak and what do i need to do the at home repair
It depends on the leak. First of all - see if you can see any cracks on the manifold - telltale signs would be a visible crack and black residue around it from exhaust. If you see that the manifold should be replaced. - welding would be a possible alternative. If there are no cracks - check all the nuts and studs to make sure they are tight. Make sure the exhaust pipe is tight and not leaking at the connection. If everything looks tight and secure - change the exhaust manifold gasket. All of that could be done at home depending on your comfort leel with the tools and time available.
1helpful
Serious Oil leak while running
The oil pressure sensor is likely leaking. The tops of them break off due to the heat from the exhaust manifold. Luckily its on the front so the exhaust manifold isnt that hard to loosen up so that you can get in there to replace the sensor. I would fix this ASAP as it is a serious fire hazard.
Changed exhaust manifold and now it redlines at start
you have a serious vacuum leak or you bent something on the throttle linkage.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
