Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
Posted on Mar 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Curved double image at bottom of TV and looks like a 3d image
Anonymous
Level 3:
  • Panasonic Master 3,459 Answers
  • Posted on Mar 06, 2010
Anonymous
Panasonic Master
Level 3:
Answers
3459
Questions
5
Helped
850017
Points
5558
Projection TVcurved double image at bottom of TV and looks like - 2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
55PW9363 55 in. Rear Projection HDTV-Ready Television: My Phillips big screen has double images and doubl...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Green channel looks curved
my tv looks like a 3D picture! it has a double image and a the outside of the picture starts to curve
Bad picture
Ur convergence is dead,U know how to solder?Buy a convergence kit.Use what in that kit.Websites have it.Tv Repair World.com,Ebay.com.
Looks every thing is double like 3d and curve in the middle
Your CONVERGENCE needs adjustment.
All TVs are different - please consult your owners manual on the procedure.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
5helpful
Multi-color double images or shadows and curved screen
Alrighty, very common problem on this set. Here's a rundown of the repair if you're a DYI:
With the back cover off you'll notice a set of boards on the bottom of the TV and a pair of boards sitting up over the two bottom boards. The problem lies in the upper-right hand board which is the color convergence power supply. Either replace or repair this board. The repair involves the main power mosfet (a three legged regulator on a heat sink) and two diodes next to it.
Next, the bottom right hand board needs to be removed and a fuse replaced next to the flyback. If you are versed in electronics I can detail the repair further otherwise you're going to have to have a shop do the repair.
Double images or halos
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
53UDX10B 53 in. Rear Projection "3D vision"
the convergence IC`s and associated resistors have to be replaced, do not repeatedly push magic focus or the alignment after the parts change out will take longer which of course means higher repair bill, good luck
2answers
Double image
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
I had the same problem with the same model earlier this year. You need to have the convergence module replaced on a circuit board inside. Expect to pay $400-$500 to a qualified repair shop.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
