Question about Hitachi 53SDX01B 53" Rear Projection Television
53UDX10B 53 in. Rear Projection "3D vision"
Our TV today looks like it's projecting in 3D - the top and bottom of the screen have double vision (red and green) and the duplicate image at the top is slanted.  It almost looks like a projector got detached inside and is projecting askew.  Is that possible? Any advice/suggestions?
Thanks
Convergence problem. Picture looks like 3D. Magic Focus does not help.
Posted by jet1 on
  • lgd1janey Dec 05, 2007
    my tv is also doing the same thing and the odd thing is my sister has the same tv and the same problem but she had her's repaired although she had a warranty it took awhile before she could get someone to pick it up and fix it and it wasn't covered under the warranty
    . when her tv came back the magic focus was replaced with another version of magic focus where you have to line up everything yourself .......she paid over 500.00 to get it repaired I haven't called a repair man yet . strange though a just had the tv cleaned and less than a month this happened .........Janey
  • Anonymous Mar 22, 2014
    picture looks 3d, "magic focus" is not fixing the problem. picture was fine last nite!?
Larry Eastman
    Novelist:
    Champion:
  • 232 Answers
The convergence IC`s and associated resistors have to be replaced, do not repeatedly push magic focus or the alignment after the parts change out will take longer which of course means higher repair bill, good luck
Posted on Nov 27, 2007
I am getting a warped 3d look at the top left side of screen and now am getting it also along the botttom of screen also. i am also having the tv kick out and the red on light blinks but when i go up to tv...
Tv have colors lines R,G,B mis alignment 3d picture.The tv convergence board it dead.The convergence board require changes 2 STK convergence ICS and some or all it resistors.The shop will cost u $300-350 for parts and labors.
Aug 25, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi projection tv 53uwx10ba - the Convergence ICs were replaced. When the PDKP bridge between convergence board and 2nd board is plugged in, it makes a noise. Kept that unplugged, the picture is...
Did set have this problem before you replaced the STKS?
I know these sets very well. If problem is different in any way from before you replaced chips.......double check all soldering or one of the new chips may be defective.
The more you tell me the better I can help.
regards, SD TECH
Aug 18, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Curved double image at bottom of TV and looks like a 3d image
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 03, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Hdtv that has double vision
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Oct 23, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Double on picture
Ur Convergence is dead.U know how to solder?Buy the convergence kit use the parts and desolder and resoder repair.Tv Repair World.com to buy.
Sep 11, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I have triple vision going plus it has started to
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi rear projection double image goes away when tapped
Your convergence chips are bad. You can set a repair kit from www.TvRepairKits.com for your model. Their kits come with all the parts and a complete photo instruction guide.
Mar 29, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Our television suddenly lost its colour alignment
Sounds TV got problem of convergence IC failure and you need to replace two ICs in convergence section.
If you are familiar with TV repair and have soldering tools then can fix it by yourself or ask help to local TV tech.
Mar 17, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Convergance problems?
did you adjust the convergence
on the menu?
Jan 11, 2008 | Hitachi 53UDX10B 53" Rear Projection...
I had the same problem with the same model earlier this year. You need to have the convergence module replaced on a circuit board inside. Expect to pay $400-$500 to a qualified repair shop.
Oct 11, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53SDX01B 53" Rear Projection Television Logo
364 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
