The orange led flashes on and off when the when DSI is charging removed battery and reinstalled and still flashes not charging unit?
I don't have experience with a DSi but with the DS lite a single flash of the orange light when a charger is plugged in means that the charging fuse has blown.
If its under warranty i'd suggest sending it in and if not take it to a local console repair shop or if your brave enough buy a new fuse off ebay and solder a new one on (tho be warned the fuses are less than a mm wide).
Regards,
SOD69
You need to replace the battery its failing to hold charge if its under warranty nintendo will do this for you, if you know anyone else with a dsi see if they mind testing the theory out by swapping batteries for a bit, turn off dsi light begore removing the batteries,
hope this helps?? try ebay for a new battery
