SOURCE: Oven door inner glass
With any plain electric oven yes, as long as it's not a microwave.
You will ofcourse loose a lot of heat and can do the same as I wrote underneath regarding a microwave oven to counter this loss. Only then wrap the foil around the door from the inside because the electric oven tends to get hot and would melt the tape.
Even when it's a microwave and you just have to cook you could
tape some aluminium foil to the door from the inside and *do* make sure there are no cracks where radiation can leak out.
SOURCE: broken glass top range....is it fixable?
Please , click on the link below:
Select model here to get part and diagram.
SOURCE: Who can replace a Admiral stove glass top?
i cracked mine too. the tops cost enough to make you just wanna buy a new stove.
SOURCE: corner broken off Frigidaire FEC30S7EC glass counter top stove
the top off these units can be purchased but a more exact model number is need. i can get you a part number and a place to purchase it they run about 208.00 dollars plus taxes if applicable and shipping.just need exact model number for example ( FEF366ABA ) there are alot of different verisons.
SOURCE: Frigidaire PLES389DCC MODEL Electrolux
318223626 -
MAIN TOP
found it listed from 230.68 at prosupplyco.com
up to 281.85 at Repairclinic.com
hope this helps,
best of luck,
ttfn
