Dell E176FP 17" LCD Monitor Logo
Posted on Jan 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor is black and button blinks - Dell E176FP 17" LCD Monitor
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 12, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
242
Points
My monitor is black.when i check transistor c5706 is short Bes to Emiter.
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jan 21, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368985
Points
33650
First, check the 4 transistors (c5706/5707) in the inverter transformer driving circuits, then also look for bad caps. See example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Screen is black when computer is turned on. Tthe monitor power button blinks, but when you push the button, the light does not stop blinking and the screen stays black.. The monitor was working and last...
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
2helpful
4answers
Monitor black but power light blink green
The 470uF 25 Volts capacitors on the power supply board are probably bad. Replace them all and tell us the result !
1helpful
What would cause your power button light on the monitor keep blinking and the screen is black and you have trouble getting the light to stay on and get the picture back on. what is the problem. thanks,...
If the button on monitor is blinking, it means your computer is either turned off or in standby mode (or in hybernation).
You should push the power button on your computer to restore it from standby (or hybernation).
2helpful
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Power blink
Horizontal output transistor is shorted or flyback problem
Black screen; blinking power light
are using dvi cable did u try to hit the input botton on screen itself thx nick
Monitor went black
Same with mine a couple days ago. I've been told the contacts have oxidized and need to be cleaned. It was going to cost about $80 to fix and no guarantee how long it would last so I just bought a new monitor.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
