20 Most Recent AOC CT720G 17" CRT Monitor Questions & Answers
Which components need to be replaced when horizontal lines appear?
What horizontal lines do you mean? I can think of several. - You could have a line of dead pixels on your monitor, this would probably be caused by wear and tear of the monitor, or because it has been handled the wrong way. - You could be experiencing 'screen tearing'. This is caused by your videocard struggling for a moment. - If you're running an older, analog monitor, it could be because the cable you're using is getting older and needs to be replaced.
3/11/2016 7:52:58 PM • AOC CT720G 17"... • Answered on Mar 11, 2016
2answers
AOC 17" Flat Monitor (silver)
Hello all.I had 2 AOC monitors with this kind of problem also and figured out the problem with this kind of monitor. All you have to do is to unscrew the monitor and get the control control switch buttons on its circuit board. There are four switch button that control the monitor with four pins each that attaches to the circuit board of AOC, another option is to replace the switch button with a brand new  control switch button which can be bought to your local electronic shop. Now i had no problem with my AOC monitor because i literally removed those switch control buttons from its circuit board.
2/17/2014 12:11:10 AM • AOC CT720G 17"... • Answered on Feb 17, 2014
0answers
0answers
3answers
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
8/4/2013 11:09:25 AM • AOC CT720G 17"... • Answered on Aug 04, 2013
Small texts display
Change the resolution , right click on desktop go to properties and then click on apearance tab. Change resolution on the slider bar under.
8/17/2012 8:09:50 AM • AOC CT720G 17"... • Answered on Aug 17, 2012
There problems with your product, because when I
If you take it apart there will be a couple of bulged caps on the power supply board, that need to be changed and that will fix your problem.
2/11/2011 5:07:07 PM • AOC CT720G 17"... • Answered on Feb 11, 2011
No power
If it won't power up the monitor is junk. There isn't much that one can do with a crt monitor which is considered to be obsolete.
I would recommend getting an lcd or led monitor instead of using a crt monitor.
2/4/2011 8:32:50 AM • AOC CT720G 17"... • Answered on Feb 04, 2011
No high voltge
2SC5929 HOT or STV9888 driver
11/18/2010 7:13:14 AM • AOC CT720G 17"... • Answered on Nov 18, 2010
1.CRT monitor powers on But no display 2. CRT
Checak that your heater voltge is correct +/- 6V and listen if your HT comes one. most common failures is the 1000uF caps thats dried as well as the hOT thats gone faulty
11/18/2010 7:08:53 AM • AOC CT720G 17"... • Answered on Nov 18, 2010
0answers
0answers
AOC 771s vertical center not working
what i did, is place it to a new one.
7/31/2010 11:40:52 AM • AOC CT720G 17"... • Answered on Jul 31, 2010
AOC CT720G 17" CRT Monitor Logo
64 questions posted
Top AOC Computers & Internet Experts
dannydoesita
Tom Chichester
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AOC Computers & Internet
Most Popular Question
no high voltge
  • Computers & Internet
