Arris SURFboard® SB5101 Cable Modem Logo
Posted on Jan 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Xbox live connection
My ISP is comcast and I have a SB51010 modem and I cannot cannot to xbox live. I can connect to the network however, I cannot connect to the internet. The problem is: cannot recognize or connect to my DNS servers? Any help would be greatly appreciated? All I wanna do is play fifa online
Thanks again
Anonymous
Level 3:
Genius:
  • Master 1,400 Answers
  • Posted on Jan 16, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1400
Questions
Helped
392958
Points
4210
HAve you entered the wep or security code for your router into the x box live.
Wep is the wireless security code found on your routers homepage.
Xbox live lagging
try to config your new modem properly........or contact u r isp
How do we connect the xbox to the internet
To connect the Xbox to the Internet you can either use a wireless or Ethernet connection. The Ethernet is the most common method and is simpler. Connect a Ethernet cable to the xBox and connect the other end to a modem from you ISP (Internet Service Provider) such as AT&T or Comcast. In the Xbox, configure the Network by setting up the connection - follow the Xbox instructions on how to enable the network connection.
4helpful
4answers
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
I have a problem getting "connection interrupted" every couple of minutes on call of duty 4 over XBOX live. My ISP is comcast and I have a 6mb download speed that I verified on my computer. I am...
Ok Well, The Connection Interrupted, can be caused by some other player, or as i should say the host, the host of the match is probably lacking of internet connection, wich is mainly causing the problem for the ConnectIon Interrupted. -Sinan
When testing the connection for xbox live it can't find the IP address.
Xbox 360 Connection Tests: IP Address
This test verifies that your Xbox 360™ console has a valid IP (Internet Protocol) address.
If your console does not pass this test:
Confirm that there are no other devices on your network with the same IP address.
If you are using a router or gateway, verify that it is configured to assign IP addresses to network devices (DHCP-enabled).
If you are connected to a router, make sure that your console'sEthernet cable is not connected to the router's LAN port rather thanits WAN port.
If you are connected directly to a modem and your ISP (Internetservice provider) requires PPPoE settings, verify that your PPPoE username and password are correct. If your ISP doesn't require PPPoEsettings, remove the PPPoE user name and password settings.
If you are connecting directly to a modem and have replaced a devicethat was connected to your modem with your Xbox 360 console or anotherdevice, turn the modem off and back on before connecting the newdevice.
If you are using a static IP address from your ISP, verify the address with a your provider.
If your console is connected to an ad-hoc network (in which devicesare connected directly to each other), it will probably not pass thistest. If your IP address is assigned automatically and your ad-hocnetwork does not include a DHCP server, this does not indicate aproblem. The test is properly reporting that a DHCP server could not becontacted. Xbox Customer Support does not support the use of ad-hocnetworking to connect to Xbox Live.
If you're using an ad-hocnetwork without a DHCP server and you can't connect to Xbox Live, checka different diagnostic test for the root of your problem.
This comes from http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/troubleshootliveconnection-testipaddress.htm
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Problems connecting to XBox live
I would strongly suggest to call Xbox techsupport for help. They will tell you what are the things taht you may try...its for free!!
1helpful
Xbox 360 connecting to Xbox Live through Westell 6100 modem
I would greatly suggest to call Xbox live Techsupport. They will help you regarding connectivity issue and its for free!!!
2answers
Wireless connection of xbox 360
you can find your I.P adress on the PC you use at home that is connected to the wireless modem.
if not theres an option on the xbox 360 to find the I.P automaticly try that!
hope this helps please rate me
Regards Grant
Xbox live
THINGS TO TRY loadTOCNode(1, 'whattotry'); Direct connection with a modem only loadTOCNode(3, 'whattotry'); 1. If you are connecting to Xbox Live by using a modem that is connected directly into your broadband socket, your IP address settings are obtained from your ISP. Set your IP address in Network Settings to Automatic. 2. If you use a static IP address that you obtained from your ISP, you must manually enter this address in the Dashboard. Contact your ISP for their static IP address if you do not know it. If the IP is not static, continue with the rest of the troubleshooting. 3. Power cycle the modem. 4. If your ISP requires PPPoE settings, verify that you have entered them correctly. 5. If your ISP does not use PPPoE authentication, do not use these fields in the Dashboard. Shared connection with a modem and a router loadTOCNode(3, 'whattotry'); 1. Power cycle both the modem and the router. 2. Try connecting the Xbox 360 console to Xbox Live by using the modem only. This eliminates any configuration problems on the router. • If this setup works without the router, there is a configuration issue with the router. See the router's documentation or contact the technical support group. 3. Verify that your router's DHCP service has been enabled. See the router's documentation or contact the technical support group. 4. The IP address that you entered in the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If your ISP requires PPPoE settings, try to connect with only the modem after you enter the PPPoE settings in Network Settings. • If you can connect, see your router documentation to configure the PPPoE settings correctly on the router. 6. If you are receiving an IP conflict error in the More Info section, turn off all the devices on the network. Try to connect with only the modem and Xbox 360 console connected. • If this works, there is a configuration issue on the routers DHCP server. See the router's documentation or contact the technical support group. Shared connection with a gateway device (combined modem and router) loadTOCNode(3, 'whattotry'); 1. Make sure that the device is turned on. 2. Verify that there is activity with the blinking lights sequence WAN, ADSL, and Internet connected power. Note These names will vary from model to model. 3. Power cycle the gateway device. 4. The IP address that you entered in to the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If you are receiving an IP conflict error in the More Info section, turn off all the other devices on the network. Try to connect with only the Xbox 360 console on the network. • If this test works, there is a configuration issue on the gateway DHCP server. See the router's documentation or contact the technical support group. Shared connection with Microsoft Windows Internet Connection Sharing loadTOCNode(3, 'whattotry'); 1. Verify that you can browse the Internet. If you cannot browse the Internet, Internet Connection Sharing is not configured correctly. 2. Power cycle the modem. If the modem does not have an on and off switch, unplug the modem from the power outlet. You cannot follow this step if you are using a USB modem. Instead, go to the next step. You must follow this step if you are switching the modem between the Xbox 360 console and a computer. 3. On the computer, click Start, click Run, type ncpa.cpl, and then click OK. 4. On the View menu, click Tiles. 5. If the connection is listed as Firewalled, the firewall may have to be configured. See your firewall documentation. 6. Enter manual settings in the Dashboard for IP address, subnet mask, DNS address and gateway: • IP Address : 192.168.0.2 • Subnet mask : 255.255.255.0 • Default Gateway : 192.168.0.1 • DNS server (Primary): 192.168.0.1 • DNS server (Secondary): 192.168.0.1If none of this works you might be banned. If you modded your xbox360 or for downloading game saves from the internet to boost you gamer score. You might be banned!
Top Arris Computers & Internet Experts
Jesse Walters
Jesse Walters
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
