Dryer is functioning but...in "timed dry" timer goes down and clothes stays wet. In Auto Cottons, clothes dries but the dryer does not time out. it keeps operating even if clothes is dry.
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Dryers have 2 basic types: AUTODRY and Electronic. The electronic moisture control relies on 2 bars inside the dryer. As wet clothes rub these bars the wetness discharges the capacitor on the moisture control board. As long as the cap don't get a full charge the timer motor will not advance forward to the end of cycle. What goes wrong on these? Wax buildup on moisture bars form a barrier that keeps wetness off them bars. The control thinks them clothes is dry and shuts her down. On autodry the timer motor advances very slowly, The motor does not work while the heating element is on. Only when the heating element is off does the timer motor advance. As them clothes gets dryer the temp inside the dryer stays warmer and therefore the dryer thermostat keeps the heater off long and the timer motor advances. Like being on a highway with traffic jam you go a little bit then stop then go a little bit more then stop. Finally you get there. So what goes wrong? The control thermostat is not functioning properly causing the heater limit to do all the work . Instead the heater limit has to do the work and it ain't a real happy camper. Makes them clothes get too hot. They come out wrinkled.
if it works on auto but not on time you have a bad timer,it's not counting down,it's better to use auto anyway,when the clothes dry the dryer shuts off on it's own,this way your not using extra electricity,if your clothes dry in 30 minutes and it's on 60 minutes it will still run after the clothes are dry on auto it doesn't.if you open the door and look around the opening you'll see a tag with the model number,your missing a couple of letters on the model number.
Problem with the timer control unit as it is not switching off until reset with the door latch.
it is possible that the dryer control relay or driver is short and giving power continuously.
Check the heat sensor in the auto setting it is usely on the drum that's what turns the dryer off when it is dry . The wet clothes get against it when they are dry it shuts off. Hope this helps
I am having the same problem on a WD9900A. The wash cycle works great. Spins fast and clothes are completely rung out. Dryer cycle heats up well. Fluffs and heats cloths. At some point during dry cycle water is injected on clothes and they end up sopping wet; much wetter than after wash. Filter is clear. Outlet pipe clear and functions well. Possible problem with dryer timer? Or washer timing kicking back on?
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
