HI Clay,Is the green lamp light on fully ie is not flashing.?
There is no reset for overheat, if the problem is like blocked vents when it is rectified the only reset is power on/off and the fatal red or flashing orange error condition should go away
I have seen a simualr model that had the lamp cover open not showing an error but stopping it from working, but I dont think it was the exact same model but worth checking the cover is on properly
How many hours has the lamp done, do you have two of these machines?
If you do please swap lamps between the two
again because this sounds like a lamp issue although we should be getting the error code unless the counter has been reset without changing the bulb for new..are you 100% sure your not using 2 dodgy bulbs and thats our issue, because Im suspect on these lamps unless of cause you can swap one into another and see it light, if that is the case then its has to be lamp contacts or a board fault but i need to know more exactly the deal with "known good lamp" and exact lights
Ensure we are fitting the lamp correctly and the contacts for the lamp are clean and fitting tight.Please ensure we have checked the silly things like lens cover, signal is being sent and pc aint asleep etc
It is 2.30 am in Oz, I'm off to bed but let me know some more info if you can and I have a dig deeper at work tommorrow for you and see if i can come up with some solution because all i can see it being now in my sleepy state is bulb, bulb contacts, lamp cover, mis reading lights, silly stuff or a board fault....
Cheers below is your user manual and the error light table
Speak soon
Cheers
Soulvisitor
User manual link
