20 Most Recent Panasonic PT-AE700U Multimedia Projector Questions & Answers
Adjustment can be performed in the main menu.
Panasonic... | Answered on Apr 15, 2017
Chances are the lamp was reinstalled and didn't get put in the right position. There could also be a problem with the concentrator/heat shield lens or light pipe (if it has one). Sounds like either someone replaced the lamp and didn't get it back together or the unit has been dropped.
Panasonic... | Answered on May 19, 2014
go to settings and select the computer mode instead of YPbPr
the image from the computer will be seen
Panasonic... | Answered on Jan 18, 2013
the heat from the lamp has damaged your LCD panel
you may need to service the projector check the air flow o avoid further damage to the panels
check the filter and see if it is blocking the air flow!
in most cases the LCD panel has to be replaced and its not worth doing so as it cost a bomb
open the bulb assembly and check if the bulb has fused / broken into pieces.if not then the ballast unit that powers the bulb is at fault and needs replacement
if the bulb has fused/broken , then probably the bulb that u had replaced 3 months back wasnt genuine!
What type of input cable are you using. YPbPr is a three or five wire hookup red, green, and blue.
Panasonic... | Answered on Dec 17, 2012
Panasonic PT-AE700U Multimedia Projector Logo
Popular Tags
69 questions posted
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Office Equipment & Supplies
Most Popular Question
panasonic pt ae700u projector need
  • Office Equipment & Supplies
