Ps2 appears to be only playing ps1 games or very simple ps2 games. it says cannot read disks on all newer games and goes into browser, click broswer and only option available is disk cannot be read
Theres a wheel in the disc drive that controls the elevation of the lens. To mod your ps2 to read burnt ps2 games ONE would alter the height of the lens by adjusting the wheel ever so slightly. There are online tutorials in the precise adjustments for different disks. (one height reads only ps1 games, another height reads ps1 and ps2 games, and one more height reads ps1/ps2 and burnt ps1/ps2 games) Your best bet would probably be to just purchase another ps2 used, but if you want to do it yourself, you can.
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
you might want to get a long q-tip and gently put alcohol on it and swap the lens.then have another tip ready to dry off. ps2 games are basiclly a dvd . and you can find info about a lawsuit that sony has against them for not being able to read dvd's.
when you change the laser it is not just a matter of remove and replace ..you have to have the right gear to set up the lense..all versions have different settings
JoTex.. The PS2 wont play blueray disks ..most of the older ps2 games have a purple or almost black color..Try checking the games to see if they are damaged,such as finger prints large scratches ect, try a dvd lens cleaner they are pretty cheep.(the disc type). the lens my be dirty,, or you can use a can of compressed air like the type for your keyboard. just spray inside with the disk tray open..hope this helps
Clean the LAsers Lens with Q-tip lightly dampened with Glass cleaner, then dry the lens. Try it see if that gets it going again.
If not your lasers lens and supporting frame is probably melting down. You will need a new laser.
Click on "repair directory" at the bottom of this screen. Then click on "Video Game consoles" Pick a good repair shop.
if u are trying to play old ps2 games the sumtimes have trouble reading them wot u could try is cleaning the games and the lazer inside the ps2 with a cleaning disk the should sort it out
the problem with god of war 2 is the ps2 lasers are not capable of reading the dual layer disks. either wait and get a ps3, change the laser - i just bought on for 3 quid on e bay brand new. the lasers are not designed to be played the amount they are played. the laser is designed to play 20 hours a week but as sony found out he avg gamer will clock up up tp 60 hours a week so the lasers are only lasting 1/3rd of the time they should. plus if they put a good laser in the machine u would one buy 1 ps2 and then 1 ps3. i have burned out 3 ps2's so far lol. just forget the game or wait till its put on platinum as these are single layerd disk
