HP Hewlett Packard Deskjet 5650 InkJet Printer Logo
Posted on Jan 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Teardrop light is flashing yellow. Green clock at left is lighted. Control panel says everything is ready but it won't print. There is no paoper jam.
  • Troy Staley
    Troy Staley Jan 13, 2018
    not that big of a deal. likely it is not able to pick paper because the pickup roller is dirty. look at the rollers that come down onto your paper in the tray. peek into it and watch. if it isn't able to grab the paper clean those rollers with a drop of dishwashing soap and a fingernail. scrape at it and you will see the dirt coming off. let it dry and it should be a little sticky still, or tacky. not try it again. it should be able to grab paper now.
Anonymous
Level 3:
President:
  • Master 357 Answers
  • Posted on Jan 07, 2010
Anonymous
Master
Level 3:
President:
Answers
357
Questions
Helped
261315
Points
1313
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
Troy Staley
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 13 Answers
  • Posted on Jan 13, 2018
Troy Staley
Contributor
Level 1:
New Friend:
Night Owl:
Answers
13
Questions
0
Helped
8843
Points
42
Most likely what the problem is is that it is not picking up paper from the tray. take the tray out and look under the printer and spot the rubber pick up rollers that come down on your paper in the tray. get a drop of dishwashing soap and with your fingernail, scrub at it a bit and get the dirt off of it. then dry it. it will feel just a little sticky. this is what you want to let it grab paper. try it again.
My 1300 hp printer still all lights on how to resolve problem
HP LaserJet 1150 and 1300 Series Printers - Understanding and Troubleshooting Control Panel Light Patterns This document explains how to interpret the light patterns on the HP LaserJet 1150 or 1300 series printer control panel. It lists the error conditions, describes the possible causes, and provides steps to resolve the conditions. Description of the control panel The control panel contains two lights and one lighted button. Patterns of light indicate printer status.Figure 1: Location of control panel c00007297.jpg 1 - Ready light 2 - Go button and light 3 - Attention light Figure 2: Light conditions c00007298.jpg 1 - Light off 2 - Light on 3 - Light blinking The following table explains the lights on the control panel. See "Status light patterns " below for an explanation of the light patterns.Light or button Description Ready light Indicates that the printer is ready to print. Go button and light To print a demo page or to continue printing while in manual feed mode, press and release the GO button. Attention light Indicates that a printer media input tray is empty, a print cartridge door is open, a print cartridge is missing, or other errors. Status light patterns This section describes the meaning of the light patterns. If a problem persists, see the flyer that came in the printer box for contact information, or click here to go to "Contacting HP support" below . Ready Light pattern c00007299.jpg Description The printer is ready to print. Action No action is necessary. To print a demo page, press and release the GO button on the control panel. Processing Light pattern c00007300.jpg Description The printer is receiving or processing data. Action Wait for the job to print. Continuable error Light pattern c00007301.jpg Description The printer is in manual feed mode. OR The printer is out of memory. Action The software controls manual feed. If manual feed mode is not wanted, change the setting from the printer properties. See the User Guide for information about changing printer properties. OR Take one of the following actions:
  • The page being printed might be too complex for the printer memory capacity. To continue printing, press and release the GO button. The printer might print a partial page, or the quality might be lower than normal.
  • Lower the resolution. See the User Guide for information about understanding print quality settings and changing print quality settings.
  • Add more memory. See the User Guide for information about installing DIMMs (HP LaserJet 1300 series only).
If the problem persists: Attention state Light pattern c00007302.jpg Description The printer is in an error state that requires operator intervention or help. The door is open, the media is out, the printer cartridge is installed incorrectly, or the media is jammed. Action
  1. Check that the printer cartridge door is completely closed.
  2. Load media into the correct input tray.
  3. Check that the print cartridge is correctly installed in the printer. (See the user guide for information about changing the print cartridge.)
  4. Check for any media jams and clear them. (See the user guide for information about clearing jams.
  5. Check that the left side panel is completely closed. If the left side panel is completely closed, open the left side panel and push the door sensor. Occassionally, if the left side panel appears closed, the sensor will still remain in the open position, generating this error. Pushing the sensor will shut the door tight, returning the printer to the normal mode.
1helpful
Wont print ready light and alarm light flashing
When the printer "Ready" and "Alarm" LEDs flash as shown, please check the following points:
1.Paper Jam: Clear the paper jam referring to "How do I clear paper jams?"
If the printer does not automatically resume printing, press the control panel button.
2.No Paper/ Misfeed:
-The paper cassette may be out of paper or not properly installed.
-If it is empty, load a new stack of paper into the paper cassette.
-If there is paper in the paper cassette, make sure it is straight.
-If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
-Reduce the amount of paper in the paper cassette, and then try again.
-Make sure you use paper that meets Brother's recommended paper specifications.
-Reinstall the paper properly, and then press the control panel button. The printer will start printing again.
1helpful
Power light flashes and won't let me print - HP3650 no paper jam
Go into your control panel, go to your printer, right click it, then choose "Cancel all print jobs". You may also have to uncheck the "Pause Printing" function.
If all else fails, get the cd. remove the printer and reinstall the software after shutting the printer down and start from scratch just like it was new. If neither of those solve it, go to http://www.hp.com and download your owners manual. There you will find a troubleshooting section that will help walk you through what to do. Hope that helps.
Kevin
6helpful
2answers
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
3helpful
Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
Solution:
Turn the printer off and then back on again.
If error returns, remove all print cartridges and turn off the printer.
Cold reset the printer:
Turn on the printer.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Wait for the printer prompt to install each print cartridge.
This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
2helpful
Lexmark E320
I am afraid to say that the fuser lamp has burned out this is replaceable part if you go to the link provided and go to parts you can get diagrams and the part # and ordering info from Lexmark
http://www.lexmark.com/lexmark/site/home/0,6932,204816596_0_0_en,00.html
best luck
Printing troubles
Paper jam:
Clear the paper jam. If the printer does not start printing, press the control panel button.
No paper:
Put paper in the printer. Then press the control panel button.
Misfeed:
Put the paper back in properly, and then press the control panel button. The printer will start printing again.
Can't print - paper light is on
turn the printer off, count to ten, then note the light sequence ie: flashing organge solid orange, flashing green or solid green
k24674
Grand Canyon Tech
Grand Canyon Tech
