Car Audio & Video Logo
Anonymous Posted on Jan 01, 2010
VU meter lamps burned out. How to change, what is replacement lamp? How about a service manual?
DROPNDEAL
Level 3:
Top Expert:
  • Pyramid Master 2,931 Answers
  • Posted on Feb 10, 2018
DROPNDEAL
Pyramid Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
932704
Points
21770
Well...Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
VU meter lamps burned out.  How to change, what is - helpful-j2fqtt4x4km4a1x1cbly0mof-5-0_10.png
1992 Chevolet G20 VAN no headlights
wow very old van.
so engine runs car drives ok , right, just head lamp problems.
HL flasher work or not, (hi beam flash switch)??????
in HIGH beam mode is cluster hi lamp glowing?
no? fuse is blown.
well a volt meter finds the cause most easiest.
and schematic from the service manual.
telling what engine or VIN first, is best
or the wrong fuse boxes are seen,, ok>?
you checked fuse but forgot this van has lots of fuesible links. like this super simple schematic shows.
nothing can be more simple, no BCM computer mess.
it can only be 5things (engine runs)
  1. fuse link
  2. dimmer
  3. HL switch
  4. both lamps burned out, nah
  5. grounds to both lamps cut/rusty.
87-93-undefined-undefined-0.jpg if both lamps lugs are at 12vdc, the ground is dead
3answers
Replaced XD300U projector lamp. Need to know how to reset lamp timer. Won,t turn on because lamp timer has expired to 0. Needs to be reset. Lost our manual. Please help.
"Reset the lamp counter
i. Press and hold Exit on the projector
for 3 seconds to display the total used
lamp time.
ii. Press Menu on the projector or on
the remote control to access the lamp
hour timer. An adjustment message
will appear.
iii. Press or to reset lamp hours
and press EXIT to leave."
I want change my headlights
WOW NO YEAR CAR>? 1973 ??????
do tell what change means.
my stock head lamp is dead and burned out
i want to replace it with new stock lamp. (spec lamp)
or upgrade it or modify it some way.
change has no meaning. not really.
if this is just normal service ,why not read that page in operators guide
here they are,
free
RTM
http://justgivemethedamnmanual.com/honda/honda-civic-sedan-owners-manuals/
if yours is not here, then post year car.
and body type as you can see ,bodies vary.
How to change bulbs in a safescan 65
read your owner manual section troubleshooting or how to replace it.
God bless you
Rear-Projection TVs have a lamp, which picks up the picture and projects it on the TV screen. A burned-out or connected lamps are two of the most common problems for Rear-Projection TVs. First, you will want to confirm the bulb is still good. If the bulb is bad then then replace it immediately. Second consult your user manual and verify the lamp and lamp cover are installed properly. Most Rear-Projection TVs have warning light which notify you when there are lamp problems. Again consult the user's manual to see what each light means.
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
1helpful
Red lamp lite on and how to reset lamp hour meter?
turn your tv on. on the tv it self press and hold the " - " like your turing it down. then on your remote press and hold the number " 0 " for five seconds. it should say the the meter has been reset to zero.
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Infocus LP725 Replacement Bulb
if you don't know exactly how many hours are on the new lamp, you can't be sure it works. since it's a mercury lamp, there will be no contenuity. check the lamp for cracks or clouding, not just burn marks.if the lamp is actually good, you may have a ballast issue.
5helpful
How to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
This should work:
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the (left and right arrow) and POWER buttons on the control panel simultaneously.
Important:
• If the 3 buttons was not pressed at the same time,
the lamp time may not be reset.
• Please confirm the TEMP indicator illuminates
about 2 seconds and the lamp time has been
reset.
• The projector will not turn on if you do not secure
the lamp lid.
• You must reset the operation time meter after you
replace the lamp.
• Do not reset the operation time meter unless the
lamp has been replaced.
Top Pyramid Car Audio & Video Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
