My TV was purchased in 2003. I have replaced the lamp once since that time. When that lamp went out, there was no warning or notice. The TV simply did not turn on. The service tech told me where to purchase a lamp, and how to replace it.
Now, I'm getting a warning message that the lamp should be replaced, and the lamp hour meter should be reset. Thinking that since the first bulb did not run its complete life cycle, the lamp meter wasn't reset when the tech was here. And, not having a warning message (as it does now), I didn't know to ask how to reset the meter. The warning message "The lamp needs to be replaced, and the lamp hour meter needs to be reset".
How do you reset the lamp hour meter
Panasonic has a PT-52LCX15 and a PT-LCX15-B, the B has PIP and the 15 doesn't so the original remote has no split button. The manual seems to be the same for both and there are no instructions for resetting the lamp timer with the buttons that are on my original Panasonic remote. Panasonic even sent me instructions for the 15-B. I've tried it with the set volume down and: play, FF, REW, VCR/DBS/CH - nothing worked. How do I reset the lamp timer for the Panasonic PT-52LCX15 not Panasonic PT-LCX15-B.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
SOURCE: Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
SOURCE: MY PANASONIC PT-52LCX35 REMOTE DOES NOT HAVE A
I can help you reset the lamp timer for your Panasonic PT-52LCX66
Projection HDTV. The buttons used are the TV's volume down and the
remote's number 0, not the 'split' or pip for your model.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
