This could be a result of a couple things. First, the furnace will automatically keep running for a short period after the thermostat shuts off because it has to blow all the hot air out of the system before it shuts off, that way, your not left with alot of heat stuck inside. Second could be the thermostat itself malfunctioning, you can pick up a cheap one at a local department store and installing them are fairly easy, especially since its mostly color coded. Some thermostats have an adjustment on them to set the unit to come on before or after the temperature reaches the desired amount. Other problems may exist, but that is the most common. Hope this helps
