20 Most Recent Hunter Fan Company 44260 Set and Save 511 Programmable Thermostat Questions & Answers
The "4" only indicates which program is currently running. This thermostat does not display furnace error codes.In a heating system that uses hot wire ignition for natural gas or propane, this behavior may indicate the furnace failed to detect a flame when the cycle starts. You may get warm air briefly, but because the flame detector isn't working, the system shuts down. After a while, it purges any gas and tries again. The controller board in the furnace may have an indicator light that flashes an error code - look for a label on the access panel that describes what it means.One common cause of this problem is a buildup of contaminants on the flame sense rod (often the same rod that heats red-hot to ignite the gas). Turn off the power to the furnace, wait for it to cool, then inspect the rod. If it has a whitish film on it, clean that off with Scotch-Brite (TM) or similar product (don't use sandpaper). The flame sensor works by measuring a tiny electrical current through the flame. A buildup of combustion products on the sensor blocks this current.Warning: if you are not absolutely certain about which part is what in the furnace, don;t take any chances, call in a professional. This is a critical gas safety component.
Hunter Fan... • Answered on Mar 27, 2021
To change the time, press Hour once. Then press and hold Hour to until it reaches the correct one (pay attention to the AM/PM notation). Do the same with the Min and Day buttons. Press Return when done. (The thermostat will leave return to the normal mode after 10 seconds without a button press.)
Now to set the program, set the switch to heat or cool depending on which you want to program first. Press Prog (this will program M-F settings) then press and hold Hour until the time you want Prog 1 to start. Press the Up or Down arrows to get to the temperature you want to reach and stay for this period. Press Prog again and use the Hour/Min/Up/Down keys to set the time and temperature for next period. Repeat for program 3 and 4 for weekdays. Press Prog again to do the same thing for the 4 possible weekend program segments. Any time left at 0:00 results in a program being skipped.
Press Prog to set the Program. These settings will not take effect until the next time change in the program. You can review the settings by pressing Prog and scrolling through the settings.
Change the switch to the other setting and repeat the programming if your system has both AC and heat.
If you want to press the AutoProg button the thermostat will use preset times and temperatures. For Heating that is 5 am 68, 7 am 60, 3 pm 68, 10 pm 62. For cooling it is 5 am 78, 7 am 85, 3 pm 78, 10 pm 82.
For more information, you can get the manual from Hunter: http://www.hunterfan.com/Support/Manuals-and-Parts-Guides/ , just enter the model number in the Search line.
I hope this helps.
Hunter Heating &... • Answered on Dec 05, 2019
Manuals Lib has the manual for the Hunter Set & Save 47300A here: https://www.manualslib.com/manual/73833/Hunter-Set-And-Save-47300a.html . This includes the installation instructions and the instructions for using the thermostat. You can download the file by pressing the Download button near the top of the page. There will be a prove you are not a robot challenge before you can get the PDF. I hope this helps. Cindy Wells
Hunter Heating &... • Answered on Jan 17, 2019
Attached is manual but make sure under temp and press hold. In my experience 4 is the program it's running also make sure breakers are on if first turning on and try turning breaker off back on to reset anything that may of locked out
Hunter Heating &... • Answered on Oct 30, 2018
Search for: Make Model parts diagram or " " parts manual
Hunter Heating &... • Answered on Dec 21, 2017
Hi Vikki, Do you hear a clicking noise when go to turn on the fire? if not, then it's probably the battery that's flat. Most ignitors need a battery to make them work. There not easy to find either, they tend to tuck them away in the most awkward places. If you pull the front grate off and using a torch, you'll have to have a look around and see if you can see the back of the battery. Pull this out and replace. If you wan't to see how it's done, put in your search engine your question: Replace ignitor for hunter gas fireplace hfs40cv3, When the results come up, go down to the 7th result which should be "youtube" and click on that. This will take you to the demonstration. Hope this helps! David
Hunter Heating &... • Answered on Dec 14, 2017
Susan, This means that the new thermostat is wired wrong. You did not post the make and model of the new one, the old one and possible the furnace and we need those in order to check your wiring and compatibility.
Hunter Heating &... • Answered on Oct 29, 2017
Can you give me more info on the thermostat? Model number maybe or Lennox Elite for example? I have never heard of these I numbers but would like to do some research on it.
Hunter Heating &... • Answered on Sep 14, 2017
Press and hold MENU for three seconds. Touch USER settings. Option 1 needs to be set to 0. Then confirm or ok. Menu to exit. If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Hunter Heating &... • Answered on Jun 04, 2017
You either have a wiring problem possibly a ground rocked loose or the motor is going out.but if you press 1 while its running and it dies sounds like motor and nothing wrong with remote
Hunter Heating &... • Answered on Apr 26, 2017
if the plate on the side says 220 volts then it will only work on 220 -250 volts outlet at a 110 volts outlet it will fail and at anything more than 250 volts it will burn up
Hunter Heating &... • Answered on Apr 20, 2016
Hunter Fan Company 44260 Set and Save 511 Programmable Thermostat Logo
2 questions posted
Top Hunter Heating & Cooling Experts
gbob59
Lawrence Oravetz
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Hunter Heating & Cooling
Most Popular Question
hunterfan 44260 blowing cold air
  • Heating & Cooling
