Question about Hunter Fan Company 44260 Set and Save 511 Programmable Thermostat
Hunterfan 44260 blowing cold air and flashing 4 blower keeps turning on and its not flowing a normal cycle, they are short turning off and then on again
Posted by sherri bonham on
Paul Bade
  • 1,688 Answers
The "4" only indicates which program is currently running. This thermostat does not display furnace error codes.
In a heating system that uses hot wire ignition for natural gas or propane, this behavior may indicate the furnace failed to detect a flame when the cycle starts. You may get warm air briefly, but because the flame detector isn't working, the system shuts down. After a while, it purges any gas and tries again. The controller board in the furnace may have an indicator light that flashes an error code - look for a label on the access panel that describes what it means.
One common cause of this problem is a buildup of contaminants on the flame sense rod (often the same rod that heats red-hot to ignite the gas). Turn off the power to the furnace, wait for it to cool, then inspect the rod. If it has a whitish film on it, clean that off with Scotch-Brite (TM) or similar product (don't use sandpaper). The flame sensor works by measuring a tiny electrical current through the flame. A buildup of combustion products on the sensor blocks this current.
Warning: if you are not absolutely certain about which part is what in the furnace, don;t take any chances, call in a professional. This is a critical gas safety component.
Posted on Mar 27, 2021
5 Related Answers
Pierre Laplante
  • 2042 Answers
SOURCE: Heater blows cold, and fan switch only works on 4 and 5
working on 4 and 5 speed that the resistor that broken cold air you got to move the selector to see the motor that move the trap hot and cold sometime when the motor was not move to the hot side for a long time its jam the motor on the passager side under dash put to hot and gently tap the motor tanks pierre
Posted on Nov 09, 2008
Anonymous
SOURCE: heater problem 2005 grand caravan
check the coolant level, I had the same problem low coolant level.....no hot water to the the heater coil.
Posted on Jan 03, 2009
emissionwiz
Marvin
  • 85239 Answers
SOURCE: Front Blower
ok, missed the part about the rear ac working, the part that causes this is called the air temperature control blend door actuator motor, it is an electric motor driven gear drive that moves the plastic door inside the air ducking to mix or shut off the hot or cold air from the ac evaporator core or the heater core, you will need to replace it.
Posted on Sep 03, 2009
Testimonial: "Great thanks that could be my problem. Is the motor by the inside coil"
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: Heater wont blow hot air in my 1998 Lincoln Navigator
the computer that controls the deflector motor are not responding and opening the door for heat, I'm sure you have climate control,check the temp setting sensor to the computer input first
Posted on Nov 01, 2009
subytech1
Brandon Johnson
  • 251 Answers
SOURCE: 2009 ford escape ac intermittent
Make sure your fan is coming on, you should hear it come on when you turn on the A/C or defrost. The most common problem for that symptom is the fan relay burns out, and the A/C comes on strong but then overheats quickly making the pressure in the condenser get too high and the pressure cycling switch automatically turns off the A/C. The condenser then cools and the process starts over. If you can locate your radiator fan fuse and relay, which will be in the fuse box under the hood, you can rule out the relay by pulling one of the same size from another system that isn't important like the fog lamps(if equipped). As long as you verify that the fan is NOT working, you would try this relay swap test as long as the fuse is still good. I work for a Ford dealer as a technician, if you brought your vehicle in for service for an A/C or heater concern and your still having problems with it. You can bring it back in for a "recheck" or "repeat" repair and they will have no right to charge you again... If I worked on someones car, and the problem came back after they left, I would seriously want to know because I care about my work and care about my name as a master technician. Just remember, you do not have to pay for repeat repairs... EVER!!
I hope this info helps!~subyguru~
Posted on Mar 31, 2012
Suzuki x4 2009 fan does not spin but when I turn air on it blows cold air.
Not sure which fan you mean. Engine cooling fan is different from heat/air blower fan.
Feb 04, 2015 | Suzuki Cars & Trucks
The thermal fuse on my Whirlpool Cabrio keeps blowing. The exhaust vent is clean and clear, what should i check next after replacing the fuse again?
If you keep blowing the thermal fuse there is a air flow restriction some where disconnect the exhaust at dryer turn on you should have a good air flow exiting machine if not check the blower wheel for lint build up if good the it is in the exhaust exiting the house this is a rarity but the thermistor which cycles heat on/off could be bad hope this helps
Mar 31, 2014 | Dryers
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
I have a weather king model 90RJ - first time I've had hot air heat..When I turn on the heat, the blower turns on right away ( blowing cold air) - I understand that the ducts have to cleared of the cold...
When the furnace first comes on there is a induced draft motor that should come on first but that forces air up the exhaust or flue,not into supply air on ductwork. It is not unusual for cold air to be blown out when burner first turns blower motor on. This should last for a short period of time, no more than a min. or two. You can watch furnace cycle by removing top front cover, I should back up here and ask is this a gas or electric unit. If it is gas you should be able to watch burner flames for a short time before blower comes on. I really need more information so I can try to ascertain what is going on. Wish I could be more help. Thank you.
Nov 12, 2010 | Weather King 10AJA3001AH Air Conditioner
My Janittol HPT 18-60 has posts marked Y, G, R, O, W2, E and C. The Hunter thermostat 44260 has fewer post connections G, RC-RH (with Jumper), Y/O, W/B, and Y1. What is the conversion and which wires are...
If your current thermostat is using all of the posts, you most likely have a dual stage heat pump system. A dual-stage heat pump system utilizes electric strip heat as backup heat for use during defrost cycles and to supplement the heat during outdoor temperatures below 30 degrees.
Here is an excerpt from the installation guide of the Hunter 44260 t-stat as well as a link to the guide itself.
"This thermostat is not designed for multi-stage heat
pump systems"
http://www.hunterfan.com/uploadedFiles/Support/Downloads/42711.pdf?n=6278
Feb 25, 2010 | Heating & Cooling
96 Blazer A/C WILL NOT BLOW ANY AIR HOT OR COLD
BEFORE YOU DO ANY HARD WORK TURN ON YOUR A/C AND BLOWER AND TAP THE BACK OF THE BLOWER MOTOR WITH A SMALL HAMMER IN A COMPLETE CIRCLE. SOUNDS LIKE YOU JUST HAVE SOME STICKING BRUSHES IN THE BLOWER MOTOR.
[email protected]
Aug 25, 2009 | 1996 Chevrolet Blazer
Furnace blower blows cold air
It is possible that you did not set the new blower on the proper speed. Black wire is high. Blue is medium. Red is low. If the fan is operating to slow it can run to hot and trip the high limit control. Make sure the filters are clean. When the old motor went bad, the problem might not have been discovered rite away your high limit control might need to be changed.
Also anytime you work on a furnace you can kick up some dust. Always clean the flame sensor.
Good Luck
HVAC Teacher
Mar 08, 2009 | Honeywell Power Humidifier: Furnace...
'98 S-10 heater blowing cold air - not hot air
will the air flow switch from floor to the mid to defrost? if so then we have a problem with the tempature door actuator. easy to replace just in tight place. Keep me posted for more help or if this was any help thanks
Jan 31, 2009 | 1998 Chevrolet S-10 Pickup
Fridg not cold
your story is very odd but likely nobody is messing with the door switch hwen you moved , or the wires could have shorted out. normally, the door switch, when you open a door would switch on a cabinet light and turn off the blower. in your case, its the reverse, as you open a door, the blower runs and if you close the door, the blower stops. im not sure if you can figure out which pair is the normally close and which one is the normally open on the door switch in order to swap them or you may rplace the door switch.
Feb 05, 2008 | Refrigerators
Hunter Fan Company 44260 Set and Save 511 Programmable Thermostat Logo
Top Hunter Heating & Cooling Experts
gbob59
Lawrence Oravetz
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
