I would not put this between the sat and tv not recommended anyhow rather use RCA plugs because of the simple fact the tuner on the VHS might be on channel 4 make sure its on 3 and the tv is on 3, see if you connect this to the sat you will experience issues
Make sure if your going to do this you take the line out from the sat that otherwise goes to the tv and put it into the line IN of the vhs then from line out to the tv, the tv on channel 3 make sure the vhs switch on the back is on 3 is it has one that is. if that does not work try to hook this up via red,wht,yellow cables se prate from co axe.
Thanks I hope this information does help please do click the accept button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
My only other suggestion would be to ry it on a different TV. if that does not work the the device is defective or went defective. There are no more ways to skin a cat here as far as this machine. If it worked before and now it does not work and your connections are just fine then there is a issue with the device. I suggested try a different way of hooking it up if that did not work ether then that confirms my thought that the device is in malfunction.
Thanks I hope this helps.
Very true and did say in the begining i beleave to check the channel, I am glad you got it working! I do not live in your area to know that so I am glad that he was able to give you some insite.
please do click the accept butto n to close the case, Thanks for the info.
did you read the part that said it worked perfectly before? I have already tried what you suggested with the three part video cable, it did not work. Do you have any other suggestions? All components are on channel 3.
Thanks for your response. I was just at a friend's house for a Christmas visit and talked to her husband about the issue. He said the same thing happened to them when they upgraded their cable serivce. He said I may have to change the tv channel to 4 for the dvd player, instead of channel 3 that works with the satellite. I just got home from their house and decided to give it a try...and I am now watching a dvd. Who would have thought....
problem solved
