20 Most Recent Sansui HDLCD-1900 19 in. LCD Television Questions & Answers
Hdlcd19wb series a - How do
Put the HDLCD19WB on a channel. Press menu on remote. Select channel on the sceen. Press enter on remote. Select auto channel memory on the screen. Press enter on the remote. Use the right arrow button on the remote to set the signal type to air for antenna or cable. Select automatic search on the screen. Press enter on the remote. Wait for search to finish. Check channels with the channel up and down buttons on the remote.
If you have any digital channels you should have them now.
The dtv signal option in the channel menu is only available when tv is tuned to a digital channel.
8/2/2018 5:29:05 PM • Sansui... • Answered on Aug 02, 2018
How do i tell if my sansui tv is analog or digital
hd lcd are all digidal the big backed tvs are analog
2/2/2015 5:48:09 PM • Sansui... • Answered on Feb 02, 2015
Wont come on
Some of the capacitors on the main board have burned
6/1/2014 7:11:23 PM • Sansui... • Answered on Jun 01, 2014
0answers
We bought a wall mount and the screws that came
it's simple get the size of the hole of your wall mount that's it
9/10/2013 2:22:23 PM • Sansui... • Answered on Sep 10, 2013
0answers
Lost power cord for sansui hdlcd1955w
if you are looking for a power cord only you can buy in any electronics store near in your area.
9/19/2012 5:05:57 AM • Sansui... • Answered on Sep 19, 2012
How do i unlock the screen with no remote....trying to get signal from laptop to screen
Click here to download the user manual to your TV. It has all details.
9/1/2012 3:30:36 PM • Sansui... • Answered on Sep 01, 2012
Tv comes on only for a few seconds then shuts off
Something is getting heated up inside and might need servicing. I suggest not to keep using the TV as this might damage more parts.
8/26/2012 6:30:16 AM • Sansui... • Answered on Aug 26, 2012
Buzzing sound from hdlcd185w series A
Return tv to store for exchange or call Sansui customer service. They will arrange to exchange tv.
1/31/2012 2:08:46 AM • Sansui... • Answered on Jan 31, 2012
2answers
Sansui hdlcd 185W
I purchased one last night and I don't have any problems with it. It turns on and off normally. When starting this TV the first time setup it prompts to leave it in store mode (probably for store display purposes) or choose home mode, then it goes to search channels from your cable or air tv.It sounds like you will need to return it. Walmart should have more TVs like this on stock. They didn't sell well on the Black Friday.
11/28/2011 6:32:47 AM • Sansui... • Answered on Nov 28, 2011
How do I connect my
Change the input on your remote
6/25/2011 7:52:54 PM • Sansui... • Answered on Jun 25, 2011
I have a 19 " sansul cant get my ilive sound bar
I hope this helps. You have to connect your sound bar to your cable box/satellite tv receiver. If you are connecting with composite or component cables you connect the video cables (either the yellow or the green blue and red cables) between the television and the cable box /satellite tv receiver. Then you connect the red and white audio portion of the cable between the cable box/satellite tv receiver and the sound bar. You are going from the OUTPUT of the cable box/satellite tv receiver to the INPUT on the television and sound bar. You use the function/source/input button on the sound bar to choose the space you plugged the cables into on it or listen to the radio or listen to your IPOD and etc.
6/11/2011 5:16:50 AM • Sansui... • Answered on Jun 11, 2011
WHITE SCEEN, HAS POWER AND SOUND. ONLY ONE WEEK
ask the store to give you the photocopy of the receipt then after 2 days bring your unit for repair
5/23/2011 8:08:31 PM • Sansui... • Answered on May 23, 2011
Need Help how to setup
In order to set up HD you need either an HD antenna, or a digital cable/satellite box. If you have cable or satellite you have to make sure you have HD service through your provider. If you do just hook up your box to your T.V. using either HDMI or component (blue, green, red). Then you'll have to look through your channels to find out where your HD channels are.
5/5/2011 6:31:30 PM • Sansui... • Answered on May 05, 2011
Picture and sound are fine. Will not find all the
First make sure you have a good outside antenna, then rescan, if you are getting some you should get them all in your area
1/17/2011 12:31:22 AM • Sansui... • Answered on Jan 17, 2011
I have a vga cable
you may need to change the resolution of the desktop it may not be correct for the input that the tv needs. also look for any buttons on the laptop that will switch the video over to the VGA output. i suggest tryin around 600X800 and see if it will show up. good luck
1/11/2011 2:33:29 PM • Sansui... • Answered on Jan 11, 2011
I bought an HP-desktop from a friend of mine, i
On current Sansui lcd and led tv's you must change your PC's refresh rate to 60hz to match the tv's refresh rate. How you do this will depend on what PC you have as well as what operating system. I hope this helps you.
Bobya.
8/27/2010 12:07:00 AM • Sansui... • Answered on Aug 27, 2010
I have hmdi cords and
This Sansui HDLCD-1900 can only do 720p MAX. The source will determine the display resolution, you do not set it at the TV, just like you do not set the PC monitor resolution at the monitor, it is done at the PC. http://reviews.cnet.com/flat-panel-tvs/sansui-hdlcd-1900/4505-6482_7-33089579.html
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
8/21/2010 4:41:12 AM • Sansui... • Answered on Aug 21, 2010
Sansui HDLCD-1900 19 in. LCD Television Logo
57 questions posted
Top Sansui Televison & Video Experts
 Grubhead
Grubhead
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
hdlcd19wb series
  • Televison & Video
