Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
Posted on Dec 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Akai PT5499hd that has suddenly lost color alignment
Hi I have an Akai PT5499hd that has suddenly lost color alignment. When trying to adjust the lamps I noticed that the yellow lamp picture appears to be distorted so no adjustment to focus, intensity or alignment will correct it. What can I do to repair or adjust? Thanks!!!
Anonymous
Level 3:
  • Akai Master 3,459 Answers
  • Posted on Apr 18, 2010
Anonymous
Akai Master
Level 3:
Answers
3459
Questions
5
Helped
850040
Points
5558
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,PioneerAkai PT5499hd that has suddenly lost color alignme - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find aAkai PT5499hd that has suddenly lost color alignme - bb0cf99.pngmg src="/uploads/images/bb0cf99.png" alt="bb0cf99.png" class="h_mi" /> http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
The color on my Akai PT5499HD projection tv is now showing yellow tint .. help!!
Most likely bad glycol in the blue picture tube (a coolant) and not cost effective to repair.
SD TECH
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
What is and how do i adjust the white balnceon my fujitsu S550 digital camers?
Adjustment is in the menu screen, you shouldn't have to go very deep as it is a frequently adjusted setting.
White Balance is how the camera interprets white depending on ambient lighting. Have you ever noticed how when you are taking pictures inside at night and all of the light comes from lamps and the flash that your pictures have a yellow look? Take a picture under flourescent lamps and the pictures look different as well? How about outside? Best true color rendition on the picture taken outside, but different than the others.
White balance is a way for the photographer to adjust the tone of the picture to accurately reproduce the true colors seen in real life in the picture. Most cameras have an automatic white balance and they usually work fairly well. But for the best results, set it manually. Your whites will be white and skin tones appear accurate.
Hope this helps! Good Luck!
Sony-50A2000 HDTV color issue
Your light engine is going bad. I would get an estimate first before trying to net fix.
The picture is double pictured with what appears to be a ghost
projection sets on occation need to be re-alligned. check your owners manual if you have one and re-align your lamps to the test screen that is displayed when you press 'menu' from your remote or from the front of the tv. This should fix alot of it and you may find the color adjustments may need adjusting after re-aligning your lamps. hope this helps. I had one and that sounds like the 'ghost' images I had till I did this.
1helpful
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Elmo trv-35g & h - showing brite yellow color on areas in picture
I'm not too familiar with this unit but in general I'd check that the lamp is the correct type, not simply worn though not burned out, and that it's seated (aligned) properly in its socket.
less likely: If you are comfortable taking a voltage reading in the socket, it should read approximately 10 - 20% higher than the rated voltage of the lamp. This is because there is no load on the circuit with the lamp out of the socket. With the lamp in, the voltage would drop a bit. If your reading is significantly lower than the lamp voltage rating, I'd suspect a wiring problem but cna't specualte further.
AKAI PT5499HD
hello I am Jaime from Mexico, i have a 54" akai pt5492s don`t turn on, but timer on in red help me please
thanks
Akai pt5499hd
Either the convergence chip has gone bad or the Focus block is bad. In any case,you will need to consult with a professional technician to solve this problem
Colour misalignment and focus
If you feel dull image and any yellow color problem you can change the lamp other wise no need to change the lamp.
There will be patten settings are there. so please inform service center service engineer will do this job.
Regards,
Prakasam
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
