My mifi XM2go radio will not turn on. I have reset, removed battery. The battery screen displays "barrery charging" and "charging complete", but when I press the power on button all I get are slight screen flashes every 10 seconds or so.
My radio was only flashing when I turned it on. When I plugged the power directly to the radio it would charge, back on the cradle work for a while - then repeat the same issue.
I replaced the power cord - same result.
I installed a new battery a month ago - has worked FINE ever since. It charges correctly - shows "charge complete" just like it should, turns off and on again fine.
The battery instructions indicated that the battery should be drained completely, then recharged every "few weeks" - so I am now going to do that (never did that in the past).
If your radio is blinking, and the battery never shows the complete charge, I would recommend trying a new battery before giving up on the radio.
Good Luck!!
Sounds like a bad battery. Try plugging DC adapter directly into the bottom of the unit and turn it on - does it still act-up? If so, bad radio; if it works with adapter only, then battery and charging issue.
