Question about Delphi XpressRC XM Satellite Radio Receiver with Vehicle Kit
Delphi XpressRC XM Radio backlight problem
The display on my XpressRC is very dim. I tried to adjust the dimming settings, but it won't get any brighter. Sometimes the display will flicker and become bright before going dim again.
Posted by jahughes12 on
Anonymous
    New Friend:
Same thing happened to mine until it permanently went dark - no brightness. Problem is with the LCD display that is defective. As this model does not have a separate filament bulb unlike the non color model, it cannot be repaired. Likely too expensive to replace the color LCD display if avalaible. Next one I buy will be a non color version which has separate bulb.
Posted on Mar 24, 2010
  • Chris M. Dec 29, 2010
    Actually, the LCD is LED backlight by a strip of leds glued to the lcd. They can be peeled away and replaced or repaired. The backlight problem occurs because the LCD cable is bent when it is assembled, eventually the cable will break after time.
    You can fix this problem by soldering a wire in place of the flat flex cable. Or you can get a strip of LEDs from another product. They're not uncommon; you can probably find them in any handheld device that uses an LCD. You'll just need to cut the strip to size.
  • dave jones Aug 05, 2012
    has anyone been able to repair theirs?
sharejoin
    New Friend:
  • 20 Answers
I got mine fixed at http://satelliteradiofix.com/delphi.html
Posted on Sep 30, 2011
Anonymous
    New Friend:
Same thing just happened yesterday to mine. Trying to find a Delphi support site . . .
Posted on Jul 09, 2010
Anonymous
    New Friend:
Mine just did the same thing...I can't even see it at night! Total rip off
Posted on Jul 02, 2010
I just bought a vtech c6729-4. The lcd display light is very dim. How do i make it brighter ?
If it's like my Alcatel, you can go to Settings, then to Display, Click on Brightness and you should get a slider that you can adjust to brighten your screen.
May 02, 2017 | The Computers & Internet
I have micro wave #JVM1790SK01 on the display panel the info is very dim is there a adjustment to make it brighter
There is not usually an adjustment. The dimness is normally caused by an exhausted display.
Oct 20, 2015 | Microwave Ovens
Adjust display brightness on frigidaire PLMV168
Good Afternoon Friend,
I understand that the display on your Frigidaire microwave, model# PLMV168, is dim and you are wondering if there is a way to make it brighter. There is not a way to make the display on your microwave brighter. That is the particular design of your appliance. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire PLMV168 Microwave Oven
NEED TO ADJUST BRIGHTNESS
You didn't post the Make, Model of Laptop or the OS? All I can suggest is to Open the Control Panel, select Power Options, set to High performance, Change Plan settings, adjust brightness or when to dim display. If you are on Battery power the displat will dim to conserve battery power. Plugging in will brighten the display. If you have a NVidia Graphics Adapter it can be a bit different. Do ALL your Windows and Laptop Manufacturer's updates.
Apr 19, 2013 | Computers & Internet
LED on my Sony ICFC218 is dim
i found that if I repeatedly press snooze/date/sleep off (big button) it will change the dim setting 3 levels... dunno how many times but I press it like 20-30 times and it works
Dec 02, 2011 | Sony ICFC218 Clock Radio
I have a CDA 7892 alpine works great but would like the display to be brighter seems a bit dim manual does not say this model can be adjusted or am i missing it any help thanks in advance
You didn't specify if you wanted the display brighter in the daytime while headlights are off or if it is too dim when the headlights are on, with respect to the rest of the instrument panel illumination. Too bright is easier to deal with but too dim is tough. If it is always too dim under but daytime and night time conditions the only way to improve brightness would be to very gently disassemble the front panel (easier if it is the removable type) and determine what provides the back lighting. If there are tiny LEDS you could painstakingly add more LEDS or swap them out for brighter LEDS. There could be a lot of guesswork determining if this or that LED was brighter than what is in the unit as built. It may just be easier to live with it as-is.
Mar 26, 2011 | Alpine CDA-7892 CD Player
Acer aspire 3000 display dim can i make it brighter?
You should be able to adjust the screen brightness using the "FN" key and the keys that have a sun on them with a arrow up and down. Or you can right click on the desktop and change the screen's brightness in the display properties. And sometimes laptops are set up to automatically lower the brightness when the power properties are set to power saver...like when running on batteries only and no ac power connected.
Nov 23, 2009 | Acer Aspire 3000 Notebook
My acer aspire 9300 screen is very dim and I cant seem to get it brighter . I can barely see the icons?
Try resetting the laptop to default settings in the BIOS. If that don't work, sounds like there's a problem with the backlight in the LCD Display.
Most laptops come with Ambient Light Sensors, that can adjust the display based on the lighting in the room.
Dec 03, 2008 | Acer Aspire 9300 Notebook
Delphi XpressRC XM Satellite Radio Receiver with Vehicle Kit Logo
3,488 people viewed this question
Top Delphi Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Eric Rotmil
Eric Rotmil
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
