Concert class am/fm/cd player manual tells you how to activate one hour timer how do you deactivate one hour timer hate it keeps turning off is installed i'n a 2008 peterbuilt truck
I am happy to tell you that THERE IS ANSWER:
In normal time mode press S, hold it, then then press D to activate (or press D again to deactivate) the alarm. You will see the symbol of Bell (above the seconds) appear (when alarm is activated) and the bell symbol will disappear (when the alarm is deactivated). Now if you FIRST press and hold D and then press S it will do the same thing (activate or deactivate the alarm). So D then S, or S then D will do the same thing for activation or deactivation of the alarm. BUT, IF YOU HEAR A BEEP (chime) SOUND when you activate or deactivate the alarm, then you actually ALSO ACTIVATED THE HOURLY CHIME!
BUT if you DO NOT HEAR THE BEEP (chime) when you activate or deactivate the alarm, then the Hourly Chime is OFF!
So (in normal time mode) try it both ways: first holding D and then pressing S, or first holding S and then pressing D (one of these will activate or deactivate the alarm WITHOUT MAKING A BEEP (chime) sound - USE THAT SEQUENCE TO DEACTIVATE THE HOURLY CHIME.
I hope this is helpful!
Press and hold 'S' button and you see all the 7 days appear at top along with alarm clock time. Now press 'M' button with out releasing 'S' button. You can see the 7 days names disappear at top. Now the hourly alarm is off
hi i locked my sim card, i went onto 02 website and went onto PUK code. it asks you to put your phone number in then comes up with the code. i put the code in and it it worked
The activating and deactivating of the 24 hour timer is via a toggle button, labeled "TIMER" on towards the right side of the top console. When the TIMER is activated, you will see a small clock symbol on the LCD display. While the unit is on, tap the TIMER button once. The clock symbol will disappear and the timer is now off.
Reactivating the timer is the same process (remember, the button is a toggle). Tap the TIMER button and you'll see the timer settings show up on the display (time on, time off, source, and volume). The little clock symbol appears again.
If you have lost your manual, you can download another one for free from this location: http://www.retrevo.com/s/JVC+SD1000
Press and hold the Time/Frequency Selector button approximately 2 seconds until the time display begins flashing on the display panel.
Within 5 seconds after the time display begins flashing press the Manual Down Turning button (<<) to adjust the hours and the Manual Up Turning button (>>) to adjust the minutes to the correct time.
Five seconds after the last hour or minute adjustment is made, the time will be set in the unit and normal operation can resume.
Contact Audiovox.com or 1-800-688-3135 and they will email (PDA) or fax a copy of the manual.
Here is a link to your owner's manual:
http://www.blaupunkt.com/us/download/SeattleMP74.pdf
It says:
Activating / deactivating demo
mode
The device is supplied from the factory
with demo mode activated. The various
functions of the device are displayed
graphically as animations in the display
during demo mode. You can also deactivate
demo mode.
➮ Press and hold down the MENU
button for longer than four seconds
to activate/deactivate demo
mode.
